Pic of mustang with RTR wheels without drop?
Old Jul 12, 2011 | 11:56 PM
perfect storm's Avatar
Like the post says. Does anyone have a pic of the mustangs with lowering springs? I know people suggest to have the car lowered for the wheels, curious as to the looks.
I have the performance package 19s and they look ok without a drop.
Old Jul 13, 2011 | 07:30 PM
908ssp's Avatar
I saw at least a half dozen Mustangs last night with RTRs and they stick out on the back not a lot but they stick out. Pity because the wheels look nice just don't fit right.
Old Jul 13, 2011 | 11:14 PM
Hytek's Avatar
I have the Roush extreme springs and they fit fine in the fenders. I wouldn't go much lower with these wheels unless you have good roads where u live. Without springs these wheels would probably give a 4x4 look in my opinion.
Old Jul 14, 2011 | 12:45 AM
Love those wheels Hytek. Great choice with the hypersilver. Side pic? Thanks.
Old Jul 14, 2011 | 12:46 AM
Other than sticking out, does having an offset like that affect anything performance wise?
Old Jul 14, 2011 | 03:28 PM
c0achmke's Avatar
They really don't stick out if you get directly over the top of the rear fender you can not see the tire. Depends on the angle you view from the front three quarter view. Pics you asked for are coming.
Old Jul 14, 2011 | 09:52 PM
Hytek's Avatar
Thanks! I'll take some more pics this weekend of other angles.
Old Jul 14, 2011 | 09:54 PM
Hytek's Avatar
None that I've noticed. If anything I can corner much harder now.
Old Jul 14, 2011 | 10:41 PM
908ssp's Avatar
Reducing the offset moves the center of the contact patch outboard which causes steering problems like tracking errors, following cracks or ridges in the road. The suspension is designed for the contact patch to be in certain spot relative to the king pin angle. That point on most modern cars is inboard of the king pin point so that the car has some degree of auto correction in the steering under sever load. That causes deflection in the lower rear bushing of the front control arm and is the reason it is so big. If the actual center point of contact is out board of the desired design point the front does not correct properly and the car wanders, stability is compromised.
Old Jul 18, 2011 | 05:44 PM
Car looks so good!
That side profile is post drop correct? Do you have any pics without the springs installed?
Thanks.
Old Jul 18, 2011 | 09:23 PM
Hytek's Avatar
Car looks so good!
Thanks.
Yes, I had the springs on before I got the wheels. There's a member with a red stang n charcoal RTR's not dropped with pics up. Search RTR's and u should find his pics.
Old Jul 20, 2011 | 08:40 AM
c0achmke's Avatar
Here is the pic you wanted sorry it took so long.
Old Jul 20, 2011 | 06:39 PM
xlover's Avatar
u have the 275s or 255s on there?
Old Jul 20, 2011 | 09:14 PM
Hytek's Avatar
Which louvers are those? They look good!
Old Jul 20, 2011 | 10:56 PM
c0achmke's Avatar
255 40 front. 275 35 rear, the quarter window louvers are ford came with the package I believe I did buy the car used but it was the sales managers demo so it was loaded so he coulld show off.
Old Jul 21, 2011 | 05:06 PM
crescent_wrench's Avatar
I haven't noticed any of that to this point, and I'm running 275's on all 4 corners.
Old Jul 22, 2011 | 12:12 AM
JimmyM's Avatar
Ford's
Old Jul 22, 2011 | 09:37 AM
Hytek's Avatar
Originally Posted by JimmyM
Ford's
Cool thanks!
Old Jul 22, 2011 | 10:54 AM
c0achmke's Avatar
Ford's
They attached with well "super Velcro" so they are easy to remove for cleaning the glass.
Old Jul 24, 2011 | 01:09 AM
Hytek, did you need an adjustable PHB bar?
