Pic of mustang with RTR wheels without drop?
Like the post says. Does anyone have a pic of the mustangs with lowering springs? I know people suggest to have the car lowered for the wheels, curious as to the looks.
I have the performance package 19s and they look ok without a drop. |
I saw at least a half dozen Mustangs last night with RTRs and they stick out on the back not a lot but they stick out. Pity because the wheels look nice just don't fit right.
1 Attachment(s)
I have the Roush extreme springs and they fit fine in the fenders. I wouldn't go much lower with these wheels unless you have good roads where u live. Without springs these wheels would probably give a 4x4 look in my opinion.
Love those wheels Hytek. Great choice with the hypersilver. Side pic? Thanks.
Other than sticking out, does having an offset like that affect anything performance wise?
1 Attachment(s)
Reducing the offset moves the center of the contact patch outboard which causes steering problems like tracking errors, following cracks or ridges in the road. The suspension is designed for the contact patch to be in certain spot relative to the king pin angle. That point on most modern cars is inboard of the king pin point so that the car has some degree of auto correction in the steering under sever load. That causes deflection in the lower rear bushing of the front control arm and is the reason it is so big. If the actual center point of contact is out board of the desired design point the front does not correct properly and the car wanders, stability is compromised.
Car looks so good!
That side profile is post drop correct? Do you have any pics without the springs installed? Thanks.
Originally Posted by Hytek
(Post 6106056)
Thanks! I'll take some more pics this weekend of other angles.
Car looks so good!
That side profile is post drop correct? Do you have any pics without the springs installed? Thanks. |
1 Attachment(s)
Here is the pic you wanted sorry it took so long.
Originally Posted by c0achmke
(Post 6108803)
255 40 front. 275 35 rear, the quarter window louvers are ford came with the package I believe I did buy the car used but it was the sales managers demo so it was loaded so he coulld show off.
Originally Posted by 908ssp
(Post 6106081)
(Post 6109112)
Which louvers are those? They look good!
Originally Posted by JimmyM
Ford's |
Ford's |
Hytek, did you need an adjustable PHB bar?
