LED fog light bulbs?
Old Sep 16, 2013 | 05:56 AM
Overboost's Avatar
Anyone running a set of LED fog lamps on a '10-12 GT with grille mounted fogs and the OEM HID lamps? I'm currently running the Hoen Xenonmatch bulbs in my fog lamps, but have given some thought to running an LED bulb instead.
These are the set I'm looking at:
http://www.vleds.com/bulb-type/drl-f...45-1-pair.html
The goal is something close to the OEM fogs on a '13-14.
Old Sep 16, 2013 | 11:04 AM
Steve... I've been running my led fogs for over a year now. They're 6000k. I used to have the hoen ones as well. I love the look. I don't remember if mine were vleds tho.... Hmmm
Attached Thumbnails LED fog light bulbs?-image-4116652890.jpg   LED fog light bulbs?-image-1017424467.jpg   LED fog light bulbs?-image-3301399749.jpg   LED fog light bulbs?-image-3166350920.jpg
Old Sep 16, 2013 | 01:14 PM
Overboost's Avatar
Thanks for the pictures. They look good, just a tad blue compared to the low beams and switchbacks.
Old Sep 16, 2013 | 02:01 PM
Correct. It's because they're 6000k. I purposely chose them for the fogs
You could go with 5000k tho... Should be a closer match.
Old Sep 16, 2013 | 03:17 PM
Overboost's Avatar
Yeah, I figured as much. How's the light output compared to the HIDs? Do they overpower the low beams or compliment them well?
Old Sep 16, 2013 | 04:31 PM
Diode Dynamics's Avatar
Former Vendor
The light output with LEDs is no-where near as solid as HID's
They are intended primarily for cosmetic purposes.
If you need help finding a good match, shoot me a PM and I'll help you out!
Thanks,
Nick C.
Old Sep 16, 2013 | 05:48 PM
Thanks,
Nick C.
This. I tried some higher end LEDs in my fogs on my 03. I went back to yellow halogen. The HIDs in the fogs didn't work for me, because my car has a relay that flashes the fogs when the alarm is armed/disarmed, so it was causing the ballasts to go out. The LEDs were the right color, but had almost zero discernible light output from the driver's seat.
Old Sep 16, 2013 | 06:09 PM
Steve, the light output does not compare to the HIDs (I did upgrade mine to 5000k). I got them purely for cosmetic purposes. Although, the LEDs still put out decent light. I got them either from jdm toy or vleds .... And yes it compliments the HIDs nicely
Old Sep 16, 2013 | 07:15 PM
Overboost's Avatar
Good. Sounds like the LED option makes sense then. What about heat from the bulbs? Any known issues there?
Old Sep 16, 2013 | 08:59 PM
Much less heat, since they're LEDs. No issues whatsoever.
Old Sep 17, 2013 | 12:00 AM
Overboost's Avatar
Not always the case. Sometimes you'll find massive heatsinks on LED bulbs to generate the light. See the OEM LED fogs for a good example.
Old Sep 18, 2013 | 08:02 PM
Newstangowner's Avatar
I installed putco 250010w led's in my fog lamps.
http://www.amazon.com/gp/aw/d/B00BZR3O46
Old Sep 19, 2013 | 09:30 AM
Overboost's Avatar
Those look pretty good! Thanks again for the help.
Old Sep 21, 2013 | 11:14 PM
TheDivaDanielle's Avatar
Steve, have you considered adding the lower fascia projector fogs? with a HID kit they actually do the job.
RCooke08GT
Feb 19, 2017 03:03 AM
mmb0329
Oct 1, 2015 10:59 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
