BMR panhard bar installed...thoughts/impressions
Old Jan 2, 2012 | 09:54 PM
  #41
Much closer alignment. Glad you took our advice and took it to get the alignment closer. Congrats on your mods
Old Jan 2, 2012 | 10:16 PM
  #42
m4a1mustang's Avatar
Originally Posted by FromZto5
Thx Steve... Yes I saw that photoshop that looked awesome! So that red z was yours? I thought it was Dan's.
It was mine. I took a ZDayZ 2010 photo with the Z and another one from ZDayZ 2011 with the Mustang at the same angle and combined them.
Old Jan 2, 2012 | 11:44 PM
  #43
Hytek's Avatar
Good to hear they got it right this time. Sucks about the swirls man....
Old Jan 3, 2012 | 09:44 AM
  #44
Yes! Now I have it all perfect, or at least within spec. I'm happy. With the amount of miles I will be putting on her and not tracking it, etc... I am sure I will have no issues. Someday, I might upgrade to some Koni's, etc... for now, I'm happy. Procal Tuner next I think.
Yeah how did you manage that? I still see your video cam mounted up front on your bumper via suction. I'd be so worried it falls out. But yeah, sweet photoshop man...
Np on the swirls... I got it all out. I look at it as another hour I got to spend with Marilyn.
Old Jan 3, 2012 | 11:43 AM
  #45
Dan and I used zip ties to tether the cameras. Here is how he set his up on his old Z:
Old Jan 7, 2012 | 01:48 PM
  #46
Krnnerdboy's Avatar
I'm glad you got your car sorted! For future reference/readers....
Drivers side will drop when the driver sits in the car and consequently will add neg camber to the drivers side. Most likely would have been even camber on your car when you were driving,which is when your tires are wearing and not when your looking at it parked.
It seems that many of you are picky with your alignment, if that's the case I'd recommend you sitting in the car with half a tank of gas to replicate your driving conditions during the alignment. Or go buy some rice bags and put it on your seat. Most performance/track alignment shops will recommend this.
As for the amount of camber on a street car, it really depends on your driving style. I'm fairly aggressive and I have the most amount of tread life with a 2-2.5 negative camber setting. Anything less and I wear through my outside before the inside even with that much negative camber. -1.8 to a -1 would be fairly negligible in tire wear, especially if your rotating with the rear since its a preset 0 camber.
As for slotting vs camber bolts. I really don't see much gain by slotting. Your essentially enlarging the hole vs shrinking the bolt to have some adjustability. Both can slip. I've been running bolts in my cars for all of my cars I tracked with no I'll effect. Btw adding camber plates usually adds around $80 to your alignment costs at least in my area. A good read on plates vs bolts...google kennybrown camber
Old Jan 8, 2012 | 03:48 PM
  #47
^ -2.5 camber? Dang.... that's a lot man. I am running -.8 now and very happy.
Old Jan 10, 2012 | 02:24 PM
  #48
jbl911's Avatar
Recently had orange koni's, steeda ultralites, gt500 strut mounts and j/m panhard installed in a '12. Toe was slightly out of spec. Camber was -1.3 opted not to correct with bolts. Passenger side pan hard adjustment nut loosened up within 3 days and gave a rattle. I installed the stock bar for now, no rear noises.
Old Jan 10, 2012 | 02:31 PM
  #49
jbl911's Avatar
Old Jan 10, 2012 | 03:14 PM
  #50
BlackMamba03's Avatar
Get a BMR Panhard Bar
Old Jan 10, 2012 | 09:37 PM
  #51
^ this. And get that toe in spec... That will cause your premature tire wear, and not your neg camber
Old Jan 10, 2012 | 09:46 PM
  #52
jbl911's Avatar
Yup toe got adjusted no problem, im going to give the j/m bar another shot, with some loctite.
Old Jan 11, 2012 | 07:11 AM
  #53
That's the neat thing about the BMR... you can adjust on the fly while installed on the car, in minutes. I believe the J/M one has to be removed, to adjust, correct?
Old Jan 11, 2012 | 09:45 AM
  #54
jbl911's Avatar
You can adjust the bar on the car its just a pita to make access the pass. side nut.
Old Jan 11, 2012 | 11:45 AM
  #55
yeah I remember that now.... part of the reason why I went with BMR.
Old Jan 11, 2012 | 12:25 PM
  #56
stang8psi's Avatar
same here!
Old Jan 15, 2012 | 06:42 PM
  #57
2012GTCS's Avatar
Im gonna be doing all this in the Spring. Steeda Ultralites, Koni Str.t's, and GT500 mounts. Any other better mounts to use? I dont want anything to be out of spec. What is the best way to go about it??
Old Jan 15, 2012 | 06:45 PM
  #58
jbl911's Avatar
My front camber was in spec with gt500 mounts and ultralites -1.1, -1.2. Within spec is up to -1.5.
Old Jan 15, 2012 | 09:26 PM
  #59
You sure? I thought it was -.75 +/- .5?
Old Jan 17, 2012 | 05:10 AM
  #60
Nocturnal'14's Avatar
OPTIMUM IMHO:
LEFT CASTER 5.0 or more
RIGHT CASTER 5.2 or more
LEFT & RIGHT CAMBER -1.3
TOE .10
THis is from Steeda's Website:
General street use:
Camber -.8° to -1.1°
Caster Maximum positive (5° or more)
Toe 3/32" (.0937") toe in
For agressive street use;
Camber: -1.2° to -1.5°
Caster: Maximum positive (5° or more)
Toe: 3/32" (.0937") toe in
For Road Race/Autocross:
Camber: -1.8° to -2.8°
Toe: 3/32 Toe in to 1/8 Toe out (Track dependent)
Drag Racing
Camber: -.3° to -.6°
Toe: 1/16" (.0625") Toe In.
