alcoa tire size
http://www.1010tires.com/TireSizeCalculator.asp
I've been using that ^^^ size calculator for years and love it ... you punch in the tire size and other sizes you wanna compare to the first size, and it tells you what the different sizes will do to your speedometer, how the heights will be, which size rims the tires will fit on, and it even shows some tires available in those sizes.
I'd never buy tires from there since they seem way overpriced, but I love that calculator ... lol
EDIT: using that calculator, it looks like you could easily do 255/35R20 / 295/30R20 if trying to fit the tires on 9" and 10" wide wheels, respectively.
If working with some wider wheels, I'd go 275/35R20 and 315/30R20 myself ... I just love the 305+ sizes ...
it wasn't an attach on you Nick by any means it was really hard to find the width and side wall height i wanted. I settled for what I have now although I wanted a wider tire but I couldn't find what I want in a set of tires. I think I will go with a mismatched next time to get the side wall and width I want in a tire
I have 295/35/19 on the rear
I went 245/40/19 in front I think
245 is kind of narrower but the key is I didn't want the back tire diameter smaller than the front
But you're right to each his own.
JonathonK
7/27/15 07:35 PM
