5.0 Badges and "GT" trunk medallion
Old 5/5/11, 09:03 AM
Arak-Nafein's Avatar
I want a more stealth look. What are my options as far as removing and/or replacing these?
My first thought is to replace the trunk GT medallion with a V6 version Tribar. Or perhaps one of the plastic decklid panels with a built-in medallion. (Will the V6 decklid panel fit a GT?)
What about the 5.0 badges on the side? Will the V6 Ponies fit in the same mounting holes? (I'm guessing the V6s have ponies there....I honestly haven't looked)
What about just removing them all together? How large are the holes that would have to be filled? Any other options as far as filling that area?
Lastly, are there any decklid panels that are medallionless?(Excluding the "ridged" CDC one. I want a smooth look) I think a clean surface would look pretty good back there.
I also plan on hiding my foglights behind some sort of grill. I'm going for a clean, sleek look.
Old 5/10/11, 09:56 AM
JScottGT's Avatar
All emblems are interchangeable. There is no way Ford would produce different fenders or decklid panels for each specific model. Every car leaves the body shop looking the same (hoods aside). The holes that locate the emblems are quite large and would need a good amount of body work to fill them in and sand smooth.
Old 5/10/11, 12:45 PM
Yeah, I had imagined it would be that way. Looks like I'll be going with pony emblems then.
Old 5/10/11, 06:04 PM
Gordo325's Avatar
My base v6 has no emblem on the fenders-no holes. With the gt 19s on it, it could very well be a de- badged gt...except of course it doesn't sound like one, or go as fast lol
Old 4/25/12, 07:35 PM
Muskao's Avatar
I take it the holes in the side fenders were the 5.0 is do not go all the way threw the finder?? I have no holes on the inside of my 2012 fender behind the 5.0 emblem.. Did I just get lucky ?? Lol
Old 4/26/12, 03:43 AM
jsimmons's Avatar
I believe that all of the various fender badges are attached with double-sided tape. The technique to remove them is use dental floss to slice behind the emblem, and then use goo-gone to remove the tape that remains on the fender.
Regarding the faux gas cap, the metal behind it does not conform to the shape of the deck lid. It is raised and has holes in it. All faux caps (GT, V6, Shelby, etc) are interchangeable for 2010-2012, but the 2013's might be different.
Old 4/26/12, 05:58 AM
JScottGT's Avatar
Are you sure you are looking right to the fender skin when you look? From what I've seen there are two holes in the fender to locate the 5.0 badge. There will still be double-sided tape to attach the badge though.
Old 4/26/12, 09:10 AM
Muskao's Avatar
Pretty sure.. I took a flash light between door and fender, was able to get finger on back of fender were the 5.0 is and didn't see or feel any holes or protruding plastic or metal..
Old 4/26/12, 10:13 AM
Hytek's Avatar
Here's what it looks like under the faux gas cap. You'll need a lot of heat and something that won't scratch the paint to pry it off. Fishing line supposedly works too.
Old 4/26/12, 11:16 AM
ShaneGT's Avatar
the 5.0 badges are HOLES .. i jsut changed mine to black 5.0s, you can see cleanly through the fenders, and without puilling the fender wells down, there is now way you get ur hand in there from the door well with the foam in the way.
Old 4/26/12, 02:10 PM
Muskao's Avatar
Holes or not there coming off... Lol
Old 4/26/12, 03:25 PM
2012GTCS's Avatar
So you cant really delete the cap then? Not easily anyway.
I want to take mine off to paint it.
John, do you think the factory tape will still have enough life to reattach? And is it easy to line bak up straight?
Old 4/26/12, 03:48 PM
Hytek's Avatar
Yeah it's pretty ugly under there. To completely delete it would call for body work. When I took mine off a lot of the tape stuck to the trunk lid. You would probably want to get some 3M tape to re-attach it. It has 2 pins that go through the lid, so it lines up perfectly.
Old 4/27/12, 09:27 PM
Muskao's Avatar
Well I can leave the 5.0, and this ( pic ) or take 5.0 off with just the powered by ford emblem. Your thoughts??
Two
One
Click image for larger version
Old 4/27/12, 10:53 PM
R1V3R5's Avatar
I have heard that "Powered by FORD" plate really fades with weather. Prepare to have an extra set to replace it next year if you decide to go that route.
Old 4/28/12, 03:44 AM
jsimmons's Avatar
[QUOTE=Muskao;6330363]Well I can leave the 5.0, and this ( pic ) or take 5.0 off with just the powered by ford emblem. Your thoughts??
I think you should have either one, but not both because two badges have dissimilar finishes. If you want to use both, get the new style of PBF badge (I know - $135 for a pair). The new style is larger and would go with the 5.0 better.
Old 4/28/12, 11:13 AM
Just keep the PBF badge. Looks really good on Kona!
Old 4/28/12, 11:22 AM
11SHELBYGT500's Avatar
Remove 5.0
Old 4/29/12, 07:23 PM
Muskao's Avatar
Ok, ShaneGT.. There are holes in fender.. My bad. I couldn't feel them, just couldn't reach that extra inch.. Looks like they are on the 0 on the 5.0. Just to clarify for others here is a pic from passenger side threw the plastic wheel well.
Old 4/30/12, 07:51 AM
bones302's Avatar
the red strip fades on the PBF badge after like 3 months. all you need to do is to cut a small strip from a red decal to fit and overlay. done.
Quick Reply: 5.0 Badges and "GT" trunk medallion
