2014 tail light bulb replacement?
Old Oct 15, 2014 | 05:01 AM
Joeywhat's Avatar
Is there any way to swap out reverse bulbs in the 13-14 tail lights? I'd prefer more output on the reverse lights. Doesn't seem like there is, but I figured I would ask.
Old Oct 15, 2014 | 06:13 AM
Gabe's Avatar
Not unless you replace the red/white LED's that make up that center section.
The LED's light up red when braking but turn white when the car is put into reverse
You could always sell the '14 tails and switch out to some tinted Raxxiom '11-12 tails, and then you can put in whatever bulbs you want
Old Oct 15, 2014 | 06:31 AM
MDkid92's Avatar
that would probably be the most awful idea ever lol!!!
Old Oct 15, 2014 | 10:49 AM
awoychosky123's Avatar
Plus you would need to change the bumper to a 2010-12 or the tail lights wont fit. I would leave them how they are it much more trouble than its worth.
Old Oct 15, 2014 | 03:55 PM
berzerk_1980's Avatar
Maybe a rear camera would help?
Old Oct 17, 2014 | 02:21 PM
MADSCOTSMAN's Avatar
Or perhaps some smaller LED lights flush mounted in the back bumper somewhere wired into the existing back up light circuit.. Like the old school mustang back up lights used to be. The 2011 Shelby GT350 had some like that..
http://www.drivearabia.com/news/2010...ustang-gt-uae/
Old Oct 17, 2014 | 03:03 PM
Joeywhat's Avatar
That would probably be difficult to pull off with the stock bumper.
I like the idea of LED lights from the factory, but it'd be nice if I could swap out the bulbs myself...
Old Oct 18, 2014 | 11:28 PM
VIP1's Avatar
How about some LED mini projectors on the package shelf mounted in the corners of the rear window.
I found this pic on Google. You can find similar items on ebay, aliexpress and Deal Extreme
Or maybe cut into the big black license plate surround to flush mount a different version there.
If you go with something like this, a relay harness would be a good idea to protect the stock wiring from the bump in wattage.
Something like this:
VLEDs use to have a high output LED License Plate Frame, but it is discontinued now:
http://www.vleds.com/lpf-922.html
However, they are working on a new version, but there is still concern that it may not properly dissipate the heat from those high output LEDs:
http://www.vleds.com/new-lpf.html
Either way, for all of these options, a relay harness would probably be a good idea for safety to prevent damage to the stock wiring.
Old Oct 18, 2014 | 11:54 PM
VIP1's Avatar
My Formula uses standard incandescent bulbs in the reverse lights and I found some drop-in 50 watt halogen replacement/upgrade bulbs at PepBoys a few years ago. Those are really bright. Unfortunately it isn't that easy on the 2013-2014 Mustang.
Old Oct 28, 2014 | 08:39 AM
WhiteBird00's Avatar
I installed a license plate frame that has a strip of white LEDs on each side for use as backup lights. I actually split the wiring between the two sides so that I could use them as strobes but for backup light use it's a simple two wire (power and ground) connection. They are quite bright enough to supplement the factory backup lights nicely.
http://www.camarocentral.com/Rear_Li...s_p/lic-36.htm
(don't shoot the messenger because they are on a Camaro site)
Old Oct 29, 2014 | 08:15 AM
Critical Mass's Avatar
I suppose my main question would be why you feel the need to make them brighter? Even with tint I have no problem seeing out the back window at night when backing up, and then there is the parking assist feature that will let me know if I'm getting close to an object. Just replacing the regular license plate bulbs with LED bulbs made a huge difference and there was no extra wiring needed.
Ecostang
Nov 3, 2022 08:50 PM
Diode Dynamics
Jun 12, 2018 03:26 PM
stewarts359
Jul 31, 2015 08:46 PM
Sylvain
Jul 16, 2015 04:34 PM
Sylvain
Jul 14, 2015 10:37 AM
