2013 GT Front end Conversion Thread! (Updated!)
Hey Guys now that I have my interior completly finished I'm about to start the task of replacing my front end of that of a 2013 GT but I need a Complete Parts list of what is needed I am already good to go with the hood I have a 2013 GT hood with Vents, and Insulator that I'm hopefully picking up from a craigslist listing I found there my first $500 dollars down the drain :bs: so now I'm just going to order the front bumper components new from Tasca but I want a complete parts list be for I do it so far the parts I have found are:
Color Code: Purchased Front Bumper Bumper Cover: DR3Z-17D957-ABPTM Valance Panel: DR3Z-17D957-AA Lower Shield: DR3Z-17626-B Closure Panel: DR3Z-8C371-A End Cover Right: DR3Z-8C391-B End Cover Left: DR3Z-8C391-A Upper Shield: BR3Z-8C291-AA Grille: DR3Z-8200-BC Molding: DR3Z-8419-BA Grille Surround: DR3Z-8A200-AA Lower Grille: DR3Z-17K945-BA Bezel Right: DR3Z-17E810-AA Bezel Left: DR3Z-17E811-AA Starky Fog lamp Conversion Harness:http://www.starkey-products.com/must...11-led-GT-2013 (10-12 GT owners will also need a H10 to H11 Converter) Fog Lamps: DR33-15A254-AE(RH)|DR33-15A255-AE(LH) Hood Assembly: Hood: DR3Z-16612-A Insulator: DR3Z-16738-B Vents: DR3Z-16C630-ABPTM(RH)|DR3Z-16C629-ABPTM(LH) I don't know if that covers it or not but if anyone has anything to add to the list I will update this I hope this will be an offical 2013 GT front end swap parts list but **** its a bunch of :bs: to do but I wanted a 2013 GT but instead I went with a 2012 v6 at the time it was a better saultion but now I dont have the heart to part with the car so im doing the next best thing, and I know alot of you are not fans of the "Catfish" bumper but I just really like the hood and I get the bonus of the gt fogs so thats my main reason for doing this. But please if anyone has any info that can contribute to this it will be greatly appreciated! My goal is to have a 2012 V6 that looks like a 2013 GT and this is the final step but I should have the first 2013 Kona blue Mustang :D Stick around or sub to the thread if you wish in a few weeks I will be test fitting the 2013 GT hood on my car hopefully I'm going to try with the bumper on first just to see if it fit then if it does not I will remove the bumper but hopefully I will have this done by the time winter is over :D Pics will come when I start doing this and after I will make a write up for anyone else that would like to do this as well! |
Hood Test Fit
Here is a small write up on how to remove your old hood and put the new one on.
Here is the hood coming of the truck. https://cimg4.ibsrv.net/gimg/themust...b4eb19c26d.jpg Hood Now you want to strip off the hood latch which is 2 10mm bolts from the hood. Then you want to remove your hood insulator. next pull the windshield fluid hose and disconnect the c-clips remove the hood water shielding https://cimg9.ibsrv.net/gimg/themust...8c5d634726.jpg https://cimg0.ibsrv.net/gimg/themust...da5800c114.jpg next grab a friend and un-bolt the 4 10mm bolts holding the hood on and remove the hood https://cimg2.ibsrv.net/gimg/themust...9ad3b98562.jpg Next put the new hood on and bolt it on. and attach the washer nozzles and other stuff and done. https://cimg6.ibsrv.net/gimg/themust...a678e9b4dc.jpg on 2012 bumper https://cimg7.ibsrv.net/gimg/themust...fc3951fb27.jpg Front Bumper Removal: Note: Most 2012 MY have holes pre drilled from the factory for the Closure Panel and End Covers (Pic coming soon) all 2010-2011 MY need holes drilled Robdis's Thread: https://themustangsource.com/forums/...ctures-535278/ https://cimg6.ibsrv.net/gimg/themust...3bb8523635.jpg Front Bumper off. https://cimg7.ibsrv.net/gimg/themust...9c3ab37204.jpg Front Bumper |
Bumper
Fog Lamps:
Out of the box https://cimg9.ibsrv.net/gimg/themust...aedd6e8abd.jpg The Connector: https://cimg4.ibsrv.net/gimg/themust...a731ccf897.jpg Plugs into h11 connector and LED Fogs<br/> Fogs Tested okay: https://cimg9.ibsrv.net/gimg/themust...215bafa053.jpg Off https://cimg4.ibsrv.net/gimg/themust...3d193d81ae.jpg On How I ran the connectors: https://cimg0.ibsrv.net/gimg/themust...c7420aee66.jpg Driver side. https://cimg3.ibsrv.net/gimg/themust...8485b6f7d9.jpg Passenger Side https://cimg4.ibsrv.net/gimg/themust...b995fba533.jpg Below the closure panel https://cimg5.ibsrv.net/gimg/themust...6a0a47c2ba.jpg Head lamp broke :P |
Updated!
| All times are GMT -6. The time now is 12:48 AM. |
