18x10 Front and Back for autocross, will it fit?
Old Jan 19, 2013 | 03:31 AM
SlowRiderr's Avatar
Im interested in getting some AMR 18x10 wheels for autocross purposes, and wondering if these wheels will fit up front with a stock suspension? And if lowered an inch will it fit? Im looking at using 285 wide street tires
Old Jan 25, 2013 | 07:36 PM
M3hunter's Avatar
Hope that this helps. Somewhere I readed of someone with this setup, that yes they will fit, but on the front ones you will need to shorten the length of the swaybar screw, because is very close and might rub with the tire when you turn.
Old Jan 26, 2013 | 06:41 AM
SlowRiderr's Avatar
Thanks for the tip. I've got 4 18x10 sve drifts on the way. Will be ordering some hankook rs3's or direzza zii's soon
Old Jun 22, 2013 | 10:37 AM
jbl911's Avatar
Just installed today. Sve drift 18x10 285/40/18. Fitment is close upfront , I shaved the sway bar end link bolt as a precaution. No rubbing lock to lock.
Old Jun 22, 2013 | 11:10 AM
Brandon302's Avatar
Nice ride, how does it do with stock camber on roads with ruts?
Old Jun 22, 2013 | 11:13 AM
jbl911's Avatar
Camber is slightly negative up front like 1.2-1.3 deg. So far feels smoother than the brembo pack 19"s, probably because of the larger sidewall. Havent felt any tramlining on the highway yet.
Old Jun 27, 2013 | 02:49 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
What offsets are the wheels?
Old Jun 27, 2013 | 05:11 PM
jbl911's Avatar
Diameter: 18 inch
Width: 10 inch
Finish: Black
Lugs: 5
Offset: +43 mm.
Backspacing: 7.2 in.
Bolt Circle: 4.5 in.
Ecostang
Nov 3, 2022 08:50 PM
JCStang
Aug 1, 2015 05:50 AM
Jul 17, 2015 05:40 PM
