18x10 Front and Back for autocross, will it fit?
Im interested in getting some AMR 18x10 wheels for autocross purposes, and wondering if these wheels will fit up front with a stock suspension? And if lowered an inch will it fit? Im looking at using 285 wide street tires
Originally Posted by SlowRiderr
(Post 6533917)
Originally Posted by M3hunter
Hope that this helps. Somewhere I readed of someone with this setup, that yes they will fit, but on the front ones you will need to shorten the length of the swaybar screw, because is very close and might rub with the tire when you turn.
3 Attachment(s)
Just installed today. Sve drift 18x10 285/40/18. Fitment is close upfront , I shaved the sway bar end link bolt as a precaution. No rubbing lock to lock.
Originally Posted by jbl911
(Post 6644687)
Camber is slightly negative up front like 1.2-1.3 deg. So far feels smoother than the brembo pack 19"s, probably because of the larger sidewall. Havent felt any tramlining on the highway yet.
What offsets are the wheels?
Originally Posted by Antigini-GT/CS
(Post 6647738)
Width: 10 inch Finish: Black Lugs: 5 Offset: +43 mm. Backspacing: 7.2 in. Bolt Circle: 4.5 in. |
