Wheels spacer
Old Feb 16, 2015 | 08:02 PM
dantheman's Avatar
Wheels spacer
Hi Guys, if you were to put wheels spacer , which thikness would you put so that it doesnt stick out too much but would be nice to look at ?
Old Feb 16, 2015 | 10:08 PM
shouldhavegottheGT's Avatar
It really depends on the wheels. If you have stock then the one inch spacers are fine. If you are going aftermarket then just got Tue right offset and you don't have to worry about it.
I've got 5mm spacers on my wheels. I wanted them to get closer to the fenders. Have 20x9.5 with a 35 offset. Make sure you get hub centric ones so there is no vibrations.
Old Feb 17, 2015 | 06:58 PM
dantheman's Avatar
Ok I have 255 40 19 ....the performance package with 3,31 ratio. I was just wondering what would be the max I can use without hitting the fender.
Old Feb 21, 2015 | 03:52 PM
RubyRedMCA_Beast's Avatar
I ran 255's with a 1 inch spacer and had no clearance issues, front and rear.
Old Jul 9, 2015 | 06:31 AM
gmwta77's Avatar
Just check out your wheels and see what size spacer you want
Old Jul 10, 2015 | 09:26 AM
TMSBOSS's Avatar
If you add a spacer and drive aggressively, Guilty as charged, Be sure you have studs capable of handling the increased load and that the spacer is hub centric, This being an extension of the hub. Several companies make them.
Some of the thicker spacers come with their own lugs. These are usually a strong set up.
If you driving the canyons hard or want to track the car, be sure you have some strength at the wheels.
On another forum a few of the track rats rented Mustang GTs at a driving school. The school had a grippier wider tire. One guy broke two stock studs and another 3. No spacers, just stock studs. The school immediately upgraded to ARP studs.
Be safe.
Old Jul 10, 2015 | 10:11 AM
Jazzman442's Avatar
Buy the Correct wheels. I have seen to many issues with them. They are really not safe. Changes the geometry of the front end.
Not safe. TMSBOSS has it right make sure if you use them to get longer studs and the correct lug nuts.
Old Jul 13, 2015 | 07:52 PM
Diehard's Avatar
Wheel offset changes the geometry of the front end too, that's why too much positive offset and/or too thick of a spacer is not recommended, especially for the front end.
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
