V6 Tune Questions
Old Sep 6, 2014 | 07:17 PM
  #81
2011 Kona Blue's Avatar
Originally Posted by KushBandit
It's a pony car :P
My wifes 2005 Mazda MPV mini van can and has obtained higher speeds than the PONY car 112 limiter.
Old Sep 6, 2014 | 07:29 PM
  #82
KushBandit's Avatar
I can imagine.
My buddy had a new Mazda 5 rental a few weeks ago and it topped out at about 120mph. Ford should have just put the same driveshaft as the GT and maybe limited the V6 to something like 130-140mph. That would have made more sense. The V6 obviously has the power to reach it. It's not like the GT driveshaft is anything special, and I don't think it would have impacted the mileage much, if any.
I just wanted to yank his chain because of the whole "muscle/pony" debate
Old Sep 6, 2014 | 07:39 PM
  #83
I can imagine.
I know you did bro. .,yank away. I laughed. I totally agree about the speed limiter should be raised by ford and a better driveshaft given.
Old Sep 6, 2014 | 10:46 PM
  #84
I can imagine. My buddy had a new Mazda 5 rental a few weeks ago and it topped out at about 120mph. Ford should have just put the same driveshaft as the GT and maybe limited the V6 to something like 130-140mph. That would have made more sense. The V6 obviously has the power to reach it. It's not like the GT driveshaft is anything special, and I don't think it would have impacted the mileage much, if any. I just wanted to yank his chain because of the whole "muscle/pony" debate
Actually in the 2015, I expect the EB cars to be limited to 130, GT to 155. That's how it usually is with base/high-po cars in Europe...
Old Sep 10, 2014 | 06:31 PM
  #85
White2010's Avatar
I can imagine.
The drive shaft in the V6 is how you get that good highway mpg. Putting the GT drive shaft in the car would drop your mpg. I don't know by how much but I'm guessing 3 to 5 mpg anyway. Not that I disagree with your idea, but just explaining why Ford went with the different drive shaft. It was all about touting the better mpg.
Old Apr 30, 2015 | 08:55 AM
  #86
JoeMidnight's Avatar
I'm going to revive this thread ( thanks to Patrick for reminding me about it!)
Hey Joey, did you ever end up getting that Steeda tune? or any tune? I'd be interested in getting your feedback based on your experience.
Old Apr 30, 2015 | 09:52 AM
  #87
tukatz's Avatar
Could you explain how the drive shaft affects MPG. It doesn't change the gearing so I don't understand how it could make a difference. I do agree I wish they had put in the GT shaft and not limited top end.
Old Apr 30, 2015 | 12:07 PM
  #88
Not unless he gets unbanned
Old Apr 30, 2015 | 12:43 PM
  #89
SpectreH's Avatar
The only way I could see the drive shaft impacting economy would be a heavier unit causing a drop because of the greater rotating mass.
Old Apr 30, 2015 | 02:43 PM
  #90
Joeywhat's Avatar
I have both a Steeda and Redliners tune. I usually use the Redliners as I like the throttle response better then the Steeda tune. I have both a race and performance tune from Redliners, the perf tune was very much like Steeda, the race tune offered significantly better throttle response.
Either way, all three tunes are good.
Old Jul 9, 2015 | 06:27 AM
  #91
gmwta77's Avatar
MPT tunes get a lot of hype
Old Jul 10, 2015 | 09:34 AM
  #92
TMSBOSS's Avatar
I can imagine.
A shaft Like the two piece in the GT would likely work. The GT shaft is a different length. Trans sits a bit more forward in a V-6. If I remember correctly, about 30MM.
Old Jul 10, 2015 | 09:10 PM
  #93
whowasthat's Avatar
for warranty purposes why not keep the stock ECU and replace it with a flashed one?
samjluck
Sep 17, 2015 10:24 PM
Kestral
Sep 2, 2015 06:52 PM
