TPMS Sensors
Old Nov 21, 2013 | 11:19 AM
FloridaSixer's Avatar
TPMS Sensors
Hey guys. I know if I purchase after market rims without the sensors the tire pressure monitor goes off but is it possible to turn it off? Can I use my BAMA tuner to turn it off?
Old Nov 21, 2013 | 05:20 PM
Siber Express's Avatar
Yes by adding the Sensors and No
Old Nov 22, 2013 | 08:44 AM
AMDanBailer's Avatar
Former Vendor
You can't turn off your TPMS light with a Bama custom Tuner. The only way you can turn off the TPMS light is by getting a set of TPMS sensors installed in your wheels.
Hope this helps!
-Dan
Old Nov 22, 2013 | 11:22 AM
Can I reuse the ones from my factory wheels?
Old Nov 22, 2013 | 11:43 AM
EastTNMustang's Avatar
Should be able to as long as your new aftermarket wheels aren't some crazy knock-offs and your Sensors won't fit. Are you buying a new set of wheels to use as your winter set? If so, recommend you just get another set of sensors vs swapping them twice a year.
Old Nov 22, 2013 | 02:45 PM
I'm buying AMR rims and they will be my new set of rims. How hard is it to swap the sensors
Old Nov 22, 2013 | 03:11 PM
numnutz's Avatar
just went thru this, bought 10th anniversary wheels, 10 minutes to swap sensors,dont even need to synchronize them. luck.
Old Nov 22, 2013 | 04:12 PM
Getportfolio's Avatar
You got lucky. You generally need new stems when you transfer them over. Also you risk damaging the fragile sensor.
Old Nov 23, 2013 | 01:58 PM
So what do I do to go about switching them over? Go to a tire store or can I do it myself
Old Dec 7, 2013 | 07:54 AM
apial's Avatar
When I put on my new snow tire wheels a few weeks ago, I installed 4 new TPMS sensor bought OEM and brand new over Ebay for 47,99 a piece
Here is the link to the auction
They are working perfect, I dont even had to go trough the learning process with them
So I would recomment to invest these 200 $ for your comfort and safty
Old Dec 7, 2013 | 08:35 AM
There all kinds of TPMS on Ebay, here is a set for $60 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=151174902194&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en Buy it now
As for Comfort and safety, I come from a world where you owned a Tire Pressure Gauge, and knew how to use it. If you are driving around waiting for the stupid light to go off you are running the pressures lower than recommended since the go off in the mid to lower 20 range
Old Dec 7, 2013 | 09:14 AM
apial's Avatar
There all kinds of TPMS on Ebay, here is a set for $60 http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en Buy it now
Maybe it was to early in the morning for my post, the 47,99 wasn't by piece it was for all 4
I'm driving 2.3 bar or 32 psi so exactly as recommend by Ford. And there was no waiting time, the monitoring was working fine just 1 minute after installation
And, I own also an pressure gauge and know how to use it but that doesn't helps you when you loose pressure during driving and maybe don't realize it fast enough. Since the car is already equipped with the system, everyone should invest less than 50 bucks for a few years of a little bit more safety.
Old Dec 7, 2013 | 10:34 AM
Actually I run 37 PSI in mine and can tell a low tire before the light comes on, but that is having a more than a Couple of Million miles of driving behind me. I have also played around with the pressures to get max performance and wear out of my tires, I have over 20,000 miles on my summer only Pirelli's with about 4/10's remaining.
All the little nannies they keep throwing into cars is just one more thing to break, but my Winter tires and wheels came with the OEM TPMS sensors and there is no relearn or light when I switch them out.
trackpack13gt
Jul 25, 2017 05:29 PM
