Suspension problems
Old Mar 20, 2016 | 05:44 PM
dantheman's Avatar
Suspension problems
Hi everyone, last week end I installed a lowering kit...with relocations brackets, PHB, LCA BMR.. But I have some noise lime if something was loose but everything isnsuper tight, did someone had this kind of prob before ? Thanks in advance
https://lmr.com/item/KYB-5300BAK/mus...ring-kit-05-14
Old Mar 20, 2016 | 06:49 PM
redonblackpony's Avatar
Is the noise coming from the front or the rear of the car? What type of noise? Squeaking, metal on metal. More info please
Old Mar 20, 2016 | 06:57 PM
dantheman's Avatar
Coming from the rear, sorry forgot about this important info, changed the shocks, springs, relocation brackets, LCA, PHB....noise is like if something was loose...but I checked everything...and can't find anything. Even emptied my trunk just in case something was doing that...tighten the top bolt of the shocks, tighten everything else too..
Old Mar 20, 2016 | 07:01 PM
What type of relocation bracket did you purchase? Some require that you weld them.
Are your bushings polyurethane? They require silicone-based grease often
Old Mar 20, 2016 | 07:07 PM
I have had and still have all kinds of weird noises from the back of my car. My entire suspension is aftermarket with Poly bushings.
My adjustable UCA had come loose and was clunking and making noise over bumps.
Factory swaybar end links as well as aftermarket ones also produce noise.
The pan hard bar if not properly greased will also make noise
Old Mar 20, 2016 | 09:04 PM
dantheman's Avatar
Originally Posted by redonblackpony
What type of relocation bracket did you purchase? Some require that you weld them. Are your bushings polyurethane? They require silicone-based grease often
These ones https://lmr.com/item/BMR-CAB005B/200...elocation-Brac
Old Mar 21, 2016 | 11:06 AM
firstang001's Avatar
I also have almost the same mods you have and also hear the same noise as you do. I think its just the aftermarket suspension parts. I learn to live with it now..
Old Mar 21, 2016 | 02:00 PM
boss man's Avatar
any time you start swapping out OEM parts with bushings to speak. You will add NVH to your car. Aftermarket parts target the performance end more than the sound that they make.
I don't want to sound harsh but is everything installed as per manufacture directions.
Is the clunk durning normal driving or just going over bumps?
How much did you lower it?
What you described sounds like its in the relocation brackets or control arms?
What type of ends are on the control arms.
Also what hole is your LCA in? sitting on the ground, do they have a slight pitch to them.
What helps the group here is a picture or 4 from different angles and the work that was done.
Old Mar 21, 2016 | 06:36 PM
GatorV6's Avatar
I got that same noise when I put in a panhard bar. Don't worry about it
Ragwingr
Mar 26, 2016 07:28 PM
ZeeGT
Mar 18, 2016 08:01 PM
cheezhed
2012-2013 BOSS 302
Mar 18, 2016 06:01 PM
bo18
Mar 1, 2016 08:27 AM
