*** Shifter Knob Swap - Have a Problem - Need Help please ***
Old Jul 26, 2014 | 06:20 AM
- GT -'s Avatar
Exclamation *** Shifter **** Swap - Have a Problem - Need Help please ***
Need a little help please...
Has anyone put a 2011-2012 stock original equipment 5.0 manual shifter **** on a 2013-2014 V6 ???
There is a 1.25 inch stem (or pedestal) that is attached to the bottom of the 2011-2012 stock shift **** that does not appear to be able to be removed. When the 2011-2012 is installed on a 2013-2014 it leaves a pretty big gap between the base of the stem that is attached to the stock 2011-2012 5.0 shift **** and the top of the black plastic disc that is at the top of the 2013-2014 shifter boot.
The original 2013-2014 shift **** is about the size of a quarter or a 50 cent piece. The base of the 2011-2012 stem that is attached to the bottom of shift **** is about the size of a dime, and the opening at the top of the shifter boot on the 2011-2012 is about the size of a dime.
The piece that is sold by American Muscle and other companies is made to take up the gap from an aftermarket shift **** that does not have the stem/pedestal attached to it like the original stock Ford one does.
I need a solution to take up the gap between the large 50 cent piece size black plastic disk that is at the top of the shifter boot on the 2013-2014 to the base of the dime size stem on the bottom of the original equipment Ford 5.0 2011-2012 shift ****.
Does anyone have a solution for this please?
Old Jul 27, 2014 | 10:58 AM
Siber Express's Avatar
The Shifter **** might be from a 401a or Boss. It needs a different shifter boot
http://www.partscheap.com/Mustang-Le...r3z-7277-b.htm
Jul 8, 2016 08:53 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Ray11
Sep 25, 2015 12:43 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
