Removing Stock Shift Knob?
Old Sep 24, 2012 | 10:23 AM
zbrewha863's Avatar
Removing Stock Shift ****?
Do you guys have a trick to removing the stock shift ****? I tried briefly, and this thing won't budge. I was going to take some channel locks to it, but I don't want to destroy the ****. I just need to remove it (audio install). Is there a trick, or just turn like hell?
Old Sep 24, 2012 | 10:34 AM
ThePope's Avatar
Should just twist off. Put some muscle into it. Hahahah
Old Sep 24, 2012 | 10:50 PM
Halfadeck's Avatar
The threads have lock tight on them. I used a rubber strap wrench.
Old Sep 24, 2012 | 11:05 PM
11SHELBYGT500's Avatar
Wrap the boot in aluminum foil and use a heat gun to heat up the base of the ****, then use a strap wrench.
Old Sep 24, 2012 | 11:35 PM
AlsCobra's Avatar
A Man Just Needs Some....
If you can get your hands on a strap wrench that might work. I would also wrap the **** with one of those nonslip kitchen pads that are for opening jars. Might help to not damage it.
Old Sep 28, 2012 | 07:00 AM
Gtstyles2's Avatar
I had that problem when I tried to remove my Boss **** to install my new shifter... It was super tight and slippery, I bought the rubber grip gloves from Harbor Freight and it came right off
mrp5150
Aug 23, 2015 06:29 AM
SilverBullet13
Aug 13, 2015 09:11 AM
