rattling when taking off
Old Jan 28, 2013 | 08:26 PM
southcarolina12's Avatar
i have a rattling noise when i take off and ive found what the problem is but im not sure how to fix it. its the piece inside that hole next to the exhaust hanger with the square hole in it. its just a piece of metal inside the frame. is it suppose to be there? also i cant find a way to take it out and it wont fit out of that hole cause its 2 big. theres one on both sides of the car.
Old Jan 29, 2013 | 01:35 AM
I don't know but I'm curious as to why they are there in the first place and if other people have/had them as well?
Old Jan 29, 2013 | 10:52 AM
it might be for the stock exhaust hangers. i think the previous owner had those hangers put on for some reason. its pretty much impossible to take them out. ive tried everything.
Old Jan 29, 2013 | 05:47 PM
i also found that the plastic piece inside my passanger side tail light is rattling. not the lens but the part thats in front of the bulb to keep it from shining straight out.
Old Jan 29, 2013 | 05:54 PM
BRADGTCS's Avatar
It is probably a nut plate. if you do not intend to change your exhaust fill the hole with some silicone sealant and that may capture the nut plate and keep it from rattling around
Old Jan 29, 2013 | 05:56 PM
i tried silicone but it wouldnt stick. would expanding foam work?
Old Jan 29, 2013 | 06:23 PM
BRADGTCS's Avatar
might be worth a shot but I would then seal the hole to keep moisture out.
Old Jan 31, 2013 | 09:16 AM
Just cover it with a small piece of dynamat, or equivalent. Same with the plastic on your taillight. My SN95 has little pieces of mat all over the interior (well, behind panels so it's not visible) haha!
Old Jan 31, 2013 | 12:47 PM
the piece slides around in it. its a hallow frame rail type of thing that it sides around in and can go all the way from around the back seat area to the back bumper when i stop and take off.
Old Jan 31, 2013 | 01:07 PM
HOSS429's Avatar
legacy Tms Member
see if a fridge magnet will capture it ..
Old Jan 31, 2013 | 05:15 PM
im sure it would but it wouldnt be strong enough to hold it from moving when the car is in motion.
Old Feb 8, 2013 | 02:09 PM
well i filled the whole hallow frame pieces on both sides and it kept the piece of metal from moving but i still had a rattling noise so i put the car on a lift and started to just checking all the nuts and bolts under the car to make sure they are tight and notice on of the exhaust clamps werent on right, so i took it off and pulled the exhaust pipes together with a c clamp and tightened the clamp back down the right way. no more rattling!
Old Apr 3, 2013 | 01:59 PM
ronnie948's Avatar
Get a very strong Magnet
Go to this site> www.magnetsource.com and get a couple of super strog magnets.
Ronnie
samjluck
Oct 26, 2015 05:17 PM
Sep 30, 2015 07:02 PM
mx5jhb
Sep 30, 2015 04:44 PM
