Procharger for Daily Driver
Contemplating the idea of adding a procharger stage II to my cyclone. I'm not looking for crazy horsepower...I'd be happy with 400 at the wheels and hopefully around 350 tq.
Does anybody have a procharged cyclone as their daily driver? I drive ~25,000 miles a year...mostly highway. Is there additional maintenance that I need to be aware of? I know the Stage II has an oiler built in.
I ProCharged my 5.0 back in July and drive about 12-13K miles a year. Only additional maintenance I have now is changing the oil in the supercharger when I change the engine oil every 5-6K miles. I have an i-1 and it has been great so far.
I realize that does not answer your question directly, but maybe it helps a little.
I don't have a cyclone but I did put a Procharger in my 2005 daily driver about 2008 and I love it! I go to the track 2-3 times a year and have about 59,000 total miles on the car. I have not had any issues or problems running it as my daily driver.
Like SpectreH said, the only additional maintenance I have is changing the oil in it when I change the motor oil.
Why not spray and go?
I programmed in a custom mode that keeps boost low until 2250 RPM, then it comes up very fast. That way at speeds under 80 mph on the interstate, I'm not boosting and cruise mileage is good. It will break the tires loose at that speed though if you want it to.
I have a procharger on my Cyclone. I am tuned for 415 rwhp and running at 8lbs. of boost. It is fine for daily driving, as you will really only be in boost on freeway on-ramps or if you want to exceed the posted speed limits. Most of my driving is to and from work and mostly on the freeway as well. I have not seen a noticeable drop in mileage with a properly set up tune. No extra maintenance except a supercharger oil change every 6K miles. Without a remote drain line it is somewhat of a hassle but certainly doable. I am the only procharged V6 in my area so my car is fairly unique in that regard. Be prepared for a lot of positive attention, as peeps will hear you coming with that blower. If you have any further questions, please ask or shoot me a PM. The procharger is the best bang for the buck as far as immediate HP/$ gains.
newtangowerner34 (12/23/17)
You are correct and I agree with SpectreH. A one piece driveshaft is a worthy upgrade, as a proper tune will be removing the speed limiter. I went with an aluminum one as I felt that the CF one was overkill.
As far as pulling the trigger on a Procharger, AM offers a 6% forum discount to members. Also I called an alternate vendor and they gave me a better discount over the phone, so you have options. I was able to get polishing and a few extras thrown in for less than the AM price with discount so it helps to call around for the best deal.
+1, I would definitely upgrade to a one piece, aluminum driveshaft and a safety loop. (I did)
I also added the remote drain hose to my Procharger. It makes changing the oil much easier.
The i-1 came with remote drain. I access it by dropping the oil change service panel.
Did you make your own remote line or did you buy the Procharger one?
https://www.google.com/search?q=proc..._AUIBygC&dpr=1
You do not have to add any extra oil. I purchased the Procharger line but it is just a simple braided steel line with fittings. I'm sure you could make your own but I don't know the fitting sizes or how much it would cost. For me it was easier to just buy theirs. I did not install it myself. A shop did it while I was having other work done.
I'm just curious as to why Procharger? Usually Paxton and Vortec make better horsepower and are more efficient. Pretty sure the other guys offer intercoolers now also. Just wondering?
Unfortunately Paxton does not make a SC kit for the 3.7. Currently there are only two SC kits on the market for the cyclone and one of them is the pro charger kit. I believe the second is Vortec.
Yes, the Tidalwave SC uses a Vortec. I would have tried that unit but it was released to the public 2 days after I had placed my order for the Procharger. I almost would have preferred the tidalwave kit since it is placed in the same location as the centrifugal SC on a V8, makes the same power as the procharger and does not replace the factory coolant tank. Oh well.
