Intake with no tune. Running too lean?
Old Sep 1, 2011 | 09:38 AM
xtc.inc's Avatar
Is anybody here running factory software with a cold air intake? I know i am.... Im running 91 octane and the Airaid CAI, but no tune. I was notified by a few members that i may be running too lean and am in risk of damaging the engine. Whats everybody's take on this? I know that sometimes while idling ive heard my car make a sound as if for a about 1 - 2 seconds a small burst of oxygen came out the exhaust, kind of like a sputter. This does not happen all the time, but it does happen every so often after idling for awhile. Whats your take on this, am I in danger of causing damage?
Car is a 2011 mustang v6
Note: On the american muscle website it says the airaid system does not require a tune.
What are some of the symptoms of running too lean?
Should i switch back to 87 octane right away?
Thanks in advance
Old Sep 1, 2011 | 10:25 AM
Ltngdrvr's Avatar
Answered on AFM.
And the octane makes no difference.
Old Sep 1, 2011 | 10:32 AM
KonaBlue5.0's Avatar
The Airaid intake can be run without a tune. You're perfectly fine running it without a tune, you're just not gaining as much power as you would with a tune.
Old Sep 1, 2011 | 09:21 PM
xtc.inc's Avatar
ive noticed that after a start up of the car, when it is idling at its normal RPM and i give it the slightest touch off throttle and then let off .... the RPM's drop to below normal... and the engine almost dies and shuts off for a second... then it goes back to idle RPM... i can keep doing this... give it the slightest hint of throttle... then let off right away... the engine will nearly die and shut down... anybody have a clue as to whats going on?
Old Sep 1, 2011 | 09:24 PM
Ltngdrvr's Avatar
Only 2-4 peak HP difference with a tune, a little more in the mid range.
This is on a V6 car, not a GT.
Old Sep 2, 2011 | 06:38 AM
So it's like I said - not gaining as much as he would with a tune.
Old Sep 2, 2011 | 05:33 PM
MustangGTPilot's Avatar
You don't mention if you are but you MUST have the insert in the airaid if you are not running a tune as it will run too lean and the MAF will not be able to function properly. I ran my 5.0 with the airaid and no tune for a while with no problems. Once I put a tune in I had to remove the insert.
Old Sep 5, 2011 | 01:24 AM
brycerichert's Avatar
Funny.... CAI and a "tune".... 2-4 "peak" hp..... I bet one could really feel that in the back when pushing that throttle to the floor!!!
Old Sep 6, 2011 | 06:59 AM
There is no insert for the V6 Airaid intake.
Old Sep 6, 2011 | 07:12 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
To me it sounds like your worrying your self for no reason. A simple cold air intake is not going to mess your car up. It's a tube with a filter on it. The stock version is a tube with a filter on it. Biggest difference between the two is aftermarket gets rid of all the baffling and creates that whistle. So I say stop worrying and drive the car.
Old Jan 21, 2012 | 11:20 PM
Masked302's Avatar
Is the cil on?
Old Jan 21, 2012 | 11:21 PM
Masked302's Avatar
Sorry cel
Old Jan 22, 2012 | 04:56 PM
Bear Eats King...
Bear ****s Bone
Nice first two posts... do you realize hoe old this thread is???
Old Jan 22, 2012 | 04:57 PM
Bear Eats King...
Bear ****s Bone
Sorry how
Old Jan 22, 2012 | 11:19 PM
xtc.inc's Avatar
never had a cel
Old Jan 22, 2012 | 11:23 PM
AlsCobra's Avatar
A Man Just Needs Some....
Originally Posted by xtc.inc
never had a cel
With no CEL the control system is not seeing a problem so no worries. If it were running lean, the cel would come on and let you know there's a problem.
Old Jan 22, 2012 | 11:33 PM
Bear Eats King...
Bear ****s Bone
That is what fuel trim is for. To automatically adjust fuel ratios within certain limits. So your good
Sep 8, 2015 10:45 AM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
