Does This Count as an Engine Mod? 427w in 2012 Mustang
Old Aug 22, 2014 | 11:23 AM
  #121
V6 Driver's Avatar
My insurance company suggested that I take out a rider or an add on for the mods only as it is something that they offer. That would cover all of the mods, while the normal insurance would cover the car. Perhaps that is an option offered by your insurance company.
Old Aug 23, 2014 | 04:34 AM
  #122
jsimmons's Avatar
Yesterday:
0) We wired up the transmission and found that the speedo does in fact work. This concludes our OEM instrument cluster stuff. The speedo, tach, and fuel gauge all seem to work.
1) We decided to bypass the sim start feature and ran a wire directly from the ignition switch to the starter relay. We no longer have any starting issues.
Today, we're going to finish up the electrical, fix the water pump, address the exhaust decibel level, and weld the rear slip joint on the drive shaft.
Old Aug 23, 2014 | 01:00 PM
  #123
Originally Posted by jsimmons
Trying to finger out a low-cost solution...
We took the axle-backs off and ran it that way, and it's WAY too loud.
I vote glass packs. Prob about 24" mid-pipe.
Old Aug 23, 2014 | 02:22 PM
  #124
Siber Express's Avatar
Thrush Turbo's sounded good on my Cleveland
Old Aug 23, 2014 | 02:58 PM
  #125
I could support this haha. Do them mid-muffler style, behind an H-pipe.
Old Aug 23, 2014 | 10:54 PM
  #126
GrnT's Avatar
I second the Thrush turbo,s
Old Aug 24, 2014 | 05:16 AM
  #127
jsimmons's Avatar
Swap Day 14:
Finished up the electrical (kinda - see item 3 and 4).
0) We don't know why, but we have to jumper the harness (in the trunk) to get the fuel pump to work.
1) Reverse lockout, clutch switch (prevents car from starting without clutch being pressed in), tack, speed, fuel gauge all seem to work
2) Connected AFR gauge and existing analog gauges
3) For some reason, the fan only gives us low-speed rotation. We decided to remove the throttle position sensor, and move to a fan switch/relay kit.
4) The shop guys want to use a NOS WOT switch to turn off the A/C. I think maybe the TPS can be used for that instead. I'm gonna do some research.
After the electrical was done, we decided to start the car again to check out water temp and oil pressure. The good news - 60-70 pounds of oil pressure. The bad news - temp went up to 235 and we shut it off. It doesn't seem like the cooling system is working like it should. Tuesday, they're gonna pull the water pump off to grind down the backing plate screws, and make sure the thermostat is working okay.
Old Aug 24, 2014 | 11:44 AM
  #128
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Air pocket in the system somewhere maybe?
Old Aug 24, 2014 | 01:21 PM
  #129
jsimmons's Avatar
That's what we think, but before we can chase that down, we gotta fix the water pump issue, so I figured we'd check the thermostat as well. I stopped the the auto parts store for necessary gaskets and a new thermostat, just in case.
Old Aug 25, 2014 | 04:54 AM
  #130
David Young's Avatar
I vote for Thrush too
Old Aug 25, 2014 | 06:29 AM
  #131
jsimmons's Avatar
I have a choice right now between these two setups:
- A used set of Flowmaster Outlaws (for $100) that came off a 2012 Boss 302. The benefit of using these is that they already have stainless tips and hangers on them. The down side is that they're 3-inch inlets, and starting behind the x-pipe, my exhaust is 2-1/2 inch Magnaflow, so I would have to adapt them to the existing pipes.
- A brand new set of Moroso SpiralFlow mufflers (also 3-inch). I would have to buy tips and hanger rods, and would still have to adapt them to the existing system.
Old Aug 26, 2014 | 05:46 AM
  #132
I was having a late 60's early 70's flashback. Everyone i knew ran CherryBombs or Thrush. I ran Thrush because they were loud (no burn in) out of the box
Old Aug 27, 2014 | 05:47 AM
  #133
jsimmons's Avatar
Well, we removed the water pump, and the shop happened to have a discarded pump, so we removed the backing plate allen-head cap screws, and replaced them with the bolts from the bad pump. Problem soolved. We'll be getting our termal rad fan switch and NOS WOT switch today, and we'll be ready to tune the car. Looking for street duty by Friday/Saturday.
Old Aug 27, 2014 | 05:57 AM
  #134
TripleBlack14's Avatar
I really look forward to these updates....can't wait until you get it on the street.
Old Aug 27, 2014 | 07:13 PM
  #135
jsimmons's Avatar
Test Drive! We drove it about 10 miles this evening (no hood or bumper cover). We should be completely done by Friday, and we're going to a car meet to celebrate. When the car is completely back together, I'll post another video or two or three.
Old Aug 27, 2014 | 07:46 PM
  #136
lime05's Avatar
I vote three
Old Sep 2, 2014 | 08:54 AM
  #137
jsimmons's Avatar
I'm building a walk-around video, but here's the car with "better" mufflers and fully dressed (hood and bumper on the car, and blue tape removed):
Shop wants to put it on the dyno possibly Saturday, but the car has a weird vibration in 6th gear on the freeway. I want to try balancing the driveshaft before throwing it on the dyno. We welded the rear slip yoke and may have introduced an imbalance. We may also need to check the pinion angle, but we're going to do the balance first because adjusting pinion angle is a pain in the azz without an adjustable UCA.
Old Sep 2, 2014 | 09:14 AM
  #138
I'm building a walk-around video, but here's the car with "better" mufflers and fully dressed (hood and bumper on the car, and blue tape removed): Video Link: https://www.youtube.com/watch?v=8ogRIRvbNhc Shop wants to put it on the dyno possibly Saturday, but the car has a weird vibration in 6th gear on the freeway. I want to try balancing the driveshaft before throwing it on the dyno. We welded the rear slip yoke and may have introduced an imbalance. We may also need to check the pinion angle, but we're going to do the balance firts because adjusting pinion angle is a pain in the *** without an adjustable UCA.
What mufflers did you switch to?
Old Sep 2, 2014 | 12:19 PM
  #139
jsimmons's Avatar
Flowmaster Outlaws
Old Sep 2, 2014 | 05:37 PM
  #140
jsimmons's Avatar
