Does This Count as an Engine Mod? 427w in 2012 Mustang
Like Father...
I ♥ Sausage
I ♥ Sausage
This may be the strangest swap I've seen in quite a while. Lots more room in there than you'd think there would be when you see it placed in. What are the specs on that engine? Is it that FRPP stroker based on the Boss 351 block?
So, my question is, what are you doing with the ECU and everything hooked up to it? I don't know the computers on these cars that well, but I'd think most stuff would be tied into it, from the radio to the message center on the instrument cluster. Maybe the ABS too? Again, I don't know crap about what's tied into the ECU...I'm just wondering.
Lookin forward to how this turns out
AFR 205 heads with 1.7 rockers
Trickflow stage 3 cam
Edelbrock Air Gap intake
850CFP QuickFuel carb
Tremec Magnum XL T56
When you can put the headers in from the top on BOTH sides, you know there's a lot of room in the engine bay.
The k-member is from BMR, made specifically to put a Windsor into a s197.
Wow nice. And not bad on the weight. I gotta assume some of that is coming from the Tremec right?
Okay, pics from day 02:
Gas pedal - had convert to a throttle cable system, so I started out with a Fox Mustang gas pedal. The holes that mount the Fox pedal are exactly the same as the left side S197 holes.
However, when we stuck the pedal on the studs, we found that the pedal is too high and too far to the left, so we fabricated an adapter plate that utilized the factory hole locations, and allowed us to position the Fox pedal in a more favorable location.
Here it is mounted in the car, along with the brake/clutch pedal setup we also had to install.
After we finished the pedal, we were able to determine where to drill the holes for the Fox (manual transmission) throttle cable.
Next, we tried installing the pre-2010 master cylinder reservoir (for the hydraulic clutch). It turns out that the reservoir is too freakin' wide, and prevents the use of the vacuum fitting on the brake booster. I had to order a new reservoir from Ford, but here's a pic with an arrow pointing to where the vacuum fitting should be.
Finally, we mounted the crank trigger wheel (from a late model 302 Bronco) and pulley, and attached the alternator bracket and two of the three a/c brackets. I got the wrong front bracket and had to order one from AM for a 351w swap. Arrgg. Here's a pic of the trigger wheel mounted:
We had issues getting the transmission in the car, so there are no more pictures from what turned out to be a very long day.
I'll be spending the next couple of days (while the shop is closed) stripping the protective wrap from the wiring harness so we can cut away the wiring we don't need.
Now begins the million details.
Thanks for flipping us the bird. Nice touch.
