Borla touring drone
Borla touring drone
I installed the borla touring axle back a few weeks ago and I am experiencing quite some drone between 2500-3000 rpm. I tried a few things to get rid of that but without success. The tourings are supposed to be without any drone ...
Any ideas what to do or check to eliminate it?
That surprises me. I think you're the first that I've heard that has this issue. I was at solo, finishing off the quad AB kit for the V6 mustang and there was a F150 that was getting the Borla touring setup installed at the shop and when he drove away, it sounded even quieter than stock!
The exhaust They mocked up is for dual / quad tip Axel back for the V6 mustang and has zero drone anywhere except the 1,900-2,000 RPM range while in 6th. It's not bad by anymeans either. But you can hear it if the windows are up.
Well, it started of o.k. but it getting worse. First it got a little bit louder which is good but by now it is too loud combined with that ugly drone!
The borlas that i had on my Camaro were great but these are sh.. I even think about switching back to stock.
I have the ATAKs and its whisper quiet when cruising. Zero drone at all. Did you install them yourself? There might be an exhaust leak somewhere where the clamps are. That could cause it. The clamps don't go straight they are kind of diaganol so they are on both the mufflers and xpipe.
Yeah, I installed them myself and I already double checked. Everything is tight and no suspected leaks as far as I can tell.
Are there different aftermarket clamps available, which are bigger maybe? Just to make sure...
Just make sure the clamps are angled so it pulls the axleback closer to the xpipe. If it is straight it is just wrapped around the flange and the exhaust will be escaping out of the sides.
Don't know if that makes sense.
I had the tourings awhile ago and got rid of them because they are way too quiet not much louder than stock. You shouldn't hear anything unless you're at WOT.
Heck.... Maybe its the axle back set that's got something wrong like some kind of defect somewhere, I wouldn't rule that out either. What i do know is that, using any car as a DD, zero drone is a must!
I was thinking that, if it wasn't resident in every gear, that would have been more proof that there may have been a way it was installed. In all honesty, it would be a good idea to take it to a shop and ask them to look over your work. Maybe a muffler shop that's familiar with the borla line products.... Or call borla direct first and see what they say?
The installation is o.k., it's been triple checked. There must be something wrong with the axle backs. I even checked the trunk if there might be the cause but didn't find anything so far.
I would check the part number to make sure you have the 'tourings'. I think they sent you the wrong ones. Just a thought..............
Just talked to someone from summit but they won't do anything about it, he said I have to talk to Borla. Actually I sent Borla a mail a week ago and didn't get an answer yet. Does anyone have any experience with Borla concerning any issue of customer service? How do they handle product problems?
