2013 V-6 Automatic Downshift Bump
Old Sep 22, 2014 | 10:41 AM
JohnnyMustang2's Avatar
the car downshifts to 1st gear just before stopping and then your jerked and bumped sometimes hard and sometimes never. Or do a slow stop and put in neutral and get ready for the bump/jerk and listen, as it travels through the driveshaft, for the rear end bang. As usually its intermittent making a diagnosis difficult. Dealer tried to fix but no success. Has anyone had this problem repaired by a Ford dealer?
Old Sep 23, 2014 | 06:57 PM
tucsondivots's Avatar
I had that happen on a 2014 vert v6 rental. I have not had it happen on my 2014, but definitely know what you are talking about.
Old Sep 24, 2014 | 05:57 AM
snarlman's Avatar
I have noticed this happening to my 2014 v6 auto, sometimes it shifts or hits hard if you are going slow and then try to accelerate. I also have noticed the downshift when stopping, both issues happen once in a while.
Old Sep 24, 2014 | 07:31 AM
awoychosky123's Avatar
This is very common had it happen with a 2014 GT and a 2013 V6 I think its just the engine compression but as long as the car drives I'm fine.
Old Sep 25, 2014 | 03:49 AM
David Young's Avatar
My 2011 v6 does this also. I 'think' the little rpm drop between 2nd gear and 3rd gear is the torque converter locking and the 'jerk' before coming to a stop is the torque converter un-locking. I'm not sure but this is what i 'think' is happening.
Old Oct 14, 2014 | 10:11 PM
roadrunner's Avatar
I get this too and i hate it!!! Wish there was a way to get rid of it.
Anyone know if gears or a driveshaft swap will help?
Old Oct 15, 2014 | 10:50 AM
You could get a manual :P
Old Oct 16, 2014 | 04:18 AM
I've changed both, didn't help.
Old Oct 16, 2014 | 11:13 AM
I had a 2011 with the foreign manual 6 speed, HORRIBLE.
Old Nov 9, 2014 | 08:18 AM
Fintile's Avatar
It's still better than the auto...
Pull fuse #47 in the engine bay. Do that for 15 mins ghen put it back it. You might just need the adaptive learning to be reset do the shift points smooth out a bit.
Old Nov 18, 2014 | 12:27 PM
Noilly Pratt's Avatar
Late to the party here, but thanks for the tip Fintile - I will try that.
I just bought mine so probably has something to do with the previous owner's habits. I had to do something similar when I let my brother borrow my previous car.
Old Nov 18, 2014 | 01:30 PM
jim010's Avatar
Intersting, my 12 V8 does this.
Old Nov 18, 2014 | 01:34 PM
zeroaviation's Avatar
Interesting...
For those who have IDS, have you cleared your transmission adaptive strategy?
-Matt
Old Nov 18, 2014 | 01:46 PM
jim010's Avatar
Does pulling the fuse as suggested in the previous post do that as well?
Old Nov 18, 2014 | 01:48 PM
I would not rely on that.
Using IDS resets the correct params, not just relying on volatile memory to be erased when power is lost.
-Matt
Old Nov 18, 2014 | 01:52 PM
jim010's Avatar
OK, I will try it. Anything I need to know.
Old Nov 18, 2014 | 02:49 PM
Nope...
It should be under the main transmission menu.
-Matt
Old Dec 2, 2014 | 09:07 AM
FordService's Avatar
Did you ever get this taken care of, JohnnyMustang2?
Deysha
Old Dec 5, 2014 | 08:18 PM
It still doing it intermittenly. Left it at dealer about 2 weeks ago for a whole day. They did not drive it long enough to experience it, in fact they only took a 2 1/2 mile ride. They checked the computer for updates found none and sent me on my way.
Old Dec 10, 2014 | 09:16 AM
I’m happy to get this escalated for you if you’d like, JohnnyMustang2. Please PM me with your VIN, dealer, mileage, full name, and best daytime number.
Deysha
