Whiteline rear suspension for 2013 Boss 302
The overall "handling" of a Boss 302 was very good, in stock form. It had a few quirks, I wanted to fix. The biggest "problem", was losing traction on hard acceleration. Even with traction control, on, the rear end would come around, and then "whip" back violently, causing total loss of control. After alot of research, I found the fix. It ain't cheap, and it took 2 mechanics "very hard", labor 4 hours. The rear seat has to be removed, and both guys need a 3-4 ft. breaker bar, because Ford uses red locktite on the bolts. They don't want you to ever change control arms, upper or lower. If you buy a Boss 302R track ready full race car, for $150,000.00, you get Whiteline upper and lower control arms, mounting brackets, panhard bar, and brace, $1000.00, installed. So what do you get for your thousand bucks? Superb traction, in any situation, no whiplash, ever, and great straight line traction. Everything is predictable, and controlled by you. You can turn off "traction controll", and do a better job, yourself!, even in rain, or bumpy roads. When you lose traction, it's gradual, and controllable. It's actually a safety factor, it would be hard to lose control, and crash. I attached a picture of the most important piece, upper control arm, and bracket.
Interesting mods...
Are these parts significantly better than other aftermarket parts?
Many guys have replaced control arms. I don't recall reading that it was that big of a deal.
They are great if your car is a track only vehicle or see's limited use but as a daily driver they require to much maintence unless your the sort that really liked daily driving a pushrod car with a solid lifter pro-stock cam and having to adjust the valves on an hourly basis.
Defintely going for these as soon as I get some free money along with the Whiteline Watts-Link
I replaced the UCA, LCAs and Panhard Bar on my 2012 Boss myself, and overall the job is much easier than it was on earlier (05-10) S197s. There's more room on the 2011+ S197, making it very easy to remove the UCA and chassis mount together without having to lower the gas tank. The bolt under the back seat is torgued to 350 ft lbs, so using a large breaker bar with a jack handle for some extra leverage worked nicely. I'm 58 years old, so your mechanics must be wimps, LOL. I'll doing the same with my 2013 real soon.
No, there is no noise, at all. Ford Racing does not have upper/lower control arms, or panhard brace, or heavy braces. Whiteline is an aftermarket, "option", for Boss 302R, and is used by Ford racing teams in US, Canada, Australia, and Europe. There is no "maintanence", at all, no grease, or anything else. You can adjust everything, to suit your needs, or for a specific track. Their parts are as good as it gets, IMO. Their Watts Link is really great, but not necessary, for a street car. I had my shocks set in position 5, but I'm going back to position 3, for more compliance, and shock travel.
Sweet!, I have UMI's roto-joint rear CAs and like the Sphoon units with the delrin bushing they transmit a helluva lot of NVH plus require constant maintence which requires greasing them every 3-5k miles and after about six months of driving I need to tighten the roto-joints due to wear (which requires removing the rotor-joint side of the arms and tightening them).
The trouble with modifying the suspension with Whiteline pieces, is it provokes more mods. I saw Ford Racing's optional wheels, 19-10 rear, 19-9 front. They're forged wheels and weigh half as much as stock Boss 302 wheels. Cutting the weight improves suspension/handling, so I'm getting new wheels in bronze/gold to "match"my Gotta Have It Green paint. Then, Toyo Proxes R8888, tires, 100 compound. Hopefully, that will be the end of my "mods". The wheels come in flat black, machined accent, silver, or gloss black. I like bronze/gold.
The wheels are made by TSW and BBS, for Ford Racing. Until recently, they only came in 18 inch, flat black. Now they have 19-9 and 19-10, in colors/trim. I saw them at Tirerack, Discount Tire, and Ford Racing, priced at $5-800.00 each. Hillbank Motorsports is a distributor/dealer for all three, and they're alot cheaper. Hillbank: www.hillbankmotorsports.com 1-888-445-5226/1-949-900-1960. They ship anywhere, and can supply sensors/stems cheap. Tuttle-Click wants $500.00 for sensors/stems kit.
American Muscle has a "replica" wheel, cast, not forged, not 20 pounds. The only forged wheels they have are Forgestar, not Ford Racing, not 19-9. Forged wheels cost a lot to make, and more than double retail price.
Except the TSW which I am not sure what the difference between rotary forged and regular forging is, but they are pretty reasonably priced.
