Sponsored by:
Sponsored by:
wheel hop
Old Sep 1, 2011 | 03:42 PM
InsidiousGT's Avatar
My '11 BBP GT hopped like crazy when stock. I installed Maximum Motorsports dual adjustable LCA's and it helped a lot, but there is still some wheel hop once in awhile (I left them at the stock length). I measured my pinion angle and it is -4 degrees. Should ideally be -1 to -2 degrees, so I'm told that I need to shorten my LCA's a bit to correct the pinion angle to totally eliminate the wheel hop. If that doesn't cure it, then I'll buy an adjustable UCA.
Did you end up adjusting your angle?
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
