What shifter does my Boss have?
What shifter does my Boss have? MGW?
Title being stated, I'm 90% sure it is a MGW shifter...
Back story:
I bought my Boss used in September '13. It was having issues going into reverse:
https://themustangsource.com/f804/12...riding-526401/
While it's at the dealer getting looked at, I get a call, hey this shifter is probably the issue and its an aftermarket one... so they wouldn't go passed there.
I took it apart and here's what I found:
I'm almost 100% sure its an MGW...
The problem is I have to row through 1 & 2 before I can go into Reverse... EVER single time!
Since it is an aftermarket part, I figured this is the place to post.
Any idea what the issue could be?
Btw, it has the Boss shifter, so it looked normal.
Thanks for your help!
Back story:
So after going to MGW and watching their installation video, I'm really sure its an MGW. I haven't been able to look underneath the car though since I don't have my own jack and stands yet.
You do have a MGW shifter. There is an adjustment you can make for the reverse issue, do a search on MGW shifter & go through the posts. I don't have a MGW, & I don't remember exactly what the adjustment was. You can also contact George @ MGW & I'm sure he can help you out.
It's very simple to adjust, there is a nut on the right side of the shifter just below the gold part, break that nut loose (use a socket or a boxed end wrench) mine was super tight. On the opposite side of that nut is the stop for the 1-2 gate, it has a small hole in it, just stick a small Allen wrench or something in there and turn it one way or the other, once it shifts good tighten the jam nut and your good to go.
Wow! I am hoping this is all it is...
If y'all haven't looked at my other thread...
The issue is that when I try and go into reverse, it wants to grind and not fully engage unless i row through 1 & 2 first.
Knowing that, y'all say its just the nut adjustment?
And yes, top two are my pics.
Krohn did you get it fixed? MGW already in your car is a godsend then
FYI, I must be one of the few MGW owners who never had to adjust any setting or reverse lockout etc ... I just installed and perfect from get go.
