Sponsored by:
Sponsored by:
Suspension install... One-time use components?
Old Jan 21, 2012 | 07:38 AM
J Tennu's Avatar
Now that I have received the bulk of the suspension parts, I am under the impression that a few components can not or should not be reused(strut spindle bolts/nuts comes to mind). Are there any other one-time use components that I may need for the complete install? Thanks in advance.
Old Jan 23, 2012 | 12:44 PM
Krnnerdboy's Avatar
Just did mine yesterday and the spindle bolts are all that's recommended. I ended up reusing mine and was able to get to the correct torque spec. Then again my car only had 2500 miles
Old Jan 23, 2012 | 01:17 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Getting to the torque isn't the problem bud.... its the holding power of the component is no longer in spec
Old Jan 23, 2012 | 01:34 PM
m4a1mustang's Avatar
Anyone have the part # handy for the spindle bolts?
Old Jan 24, 2012 | 01:15 PM
J Tennu's Avatar
-Strut-To-Wheel Spindle Bolt(2 Required per Strut) [Part # W714652]
-Strut-To-Wheel Spindle Flagnut(2 Required per Strut) [Part # W714653]
Old Jan 24, 2012 | 01:17 PM
Thank you sir.
Old Jan 24, 2012 | 04:22 PM
who's Bud?
Old Jan 24, 2012 | 05:09 PM
Bear Eats King...
Bear ****s Bone
Originally Posted by Glenn
who's Bud?
Really........
Old Mar 16, 2012 | 02:52 PM
5PTOHH's Avatar
Any place online we can get these? I am deployed and trying to have all my parts ready for when I get home.
Old Mar 16, 2012 | 03:09 PM
I ordered mine from Tousley Ford.
Old Mar 16, 2012 | 05:04 PM
5PTOHH's Avatar
Thank you.
Old Mar 17, 2012 | 02:14 PM
devildog1679's Avatar
Never heard of anyone using the stockers with a failure.
Old Mar 17, 2012 | 05:35 PM
slostang's Avatar
Cheap insurance....
Old Mar 17, 2012 | 05:43 PM
Originally Posted by slostang
Cheap insurance....
This. Some of those parts are only designed to be torqued to spec one time. If you remove them it's best to replace them with new parts. It's cheap and you know you're good to go for as long as you keep those struts on the car. :tup:
Old Mar 17, 2012 | 05:46 PM
yugoboss's Avatar
You can reuse them with no problem.
Old Mar 17, 2012 | 05:49 PM
Perhaps you can, but it's cheap insurance to replace them.
Old Mar 17, 2012 | 07:13 PM
Ministang's Avatar
Not so cheap if you're changing things around to tweak alignment settings or to try different parts with any sort of frequency. I reused them when installing my current suspension, and will reuse them again when I return to stock springs in the next couple of months.
CiniZter
25
Apr 28, 2016 05:41 PM
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
robjh22
Sep 8, 2015 12:31 PM
