Sponsored by:
Sponsored by:
Steeda Upper Control Arms & Chassis Mount
Old Jul 10, 2012 | 02:35 PM
SteedaBrandon's Avatar
Former Vendor
http://youtu.be/HdsITMgsJZ0
http://www.steeda.com/store/steeda-m...ntrol-arm.html
Need to reduce wheel hop and improve traction? Steeda's upper 3rd links will do the job. The Steeda adjustable upper 3rd link for S197 Mustangs gives you the ability to set your pinion angle and eliminate the torque deflection associated with the factory piece. This upper 3rd link uses our track proven three piece bushing package using soft outer bushings a hard center bushing on the axle end. This proven combination helps control axle wind up, wheel hop under acceleration, and allows for proper articulation without deflection for improved handling and cornering stability.
Product Benefits
• Adjustable pinion angle for optimum traction
• Better handling with more stable cornering
• Three piece urethane bushings for better traction
• Competition tested & proven
Shoot me a PM if I can be of help with these.
bones302
Oct 7, 2015 04:42 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
