Shift issue after tune with my Auto.
At WOT the car blasts into second gear and breaks the back end loose. However, 50% of the time when the car goes into second spinning it immediately shifts to 3rd and then downshifts again into second after gaining traction. Is there anyway I can get this resolved in the tuner???
Well with six ratios in the auto you are spinning enough that your blowing right past the shift point going into third, then one you hook up in third and the throttle is still 100% it forces the car to downshift back into second. More of a driver issue then in the tune. They could soften the shift so that it doesn't shift as hard then it wouldn't break loose the tires as easily.
Thanks for the insult on my driving abilities Going For Broke. Kinda of funny, Gus told me the same thing today. It is a traction issue only thank Goodness. Drag radials will cure it. I was racing a C6 Vette when it happened(it had happened before but I was racing when it happened this time so I had to figure out what was the deal) . BTW the 5.0 still took the Vette folks. Once it downshifted back to second I pulled on him 2-3 lengths past 100mph
I've never owned an automatic car personally, but I actually heard that happening in one of the well-recognized tuner's drag race video. I didn't quite get what was going on, hearing the motor rev up, then die down, then rev up again..you've answered my question - buy radials! Haha
Why do all the auto tranny builders offer manual shifting?
Look at his first post for the issue.
If his car is not hooking up & the tranny is hunting for a gear it is going to slow him down. Shifting back and forth will slow you down, I'm sure you can agree on that.
If he is shifting manually he can shift up when he loses traction & carry that momentum through the gear. It may be ugly, but you may salvage a win.
More importantly, he needs to dial his car in so he doesn't break loose. Once accomplished he can let the auto do it's thing if he prefers.
Pedal to the metal is not always fast. Sometimes you have to back off.
Ok, I think I have it figured out now. Slidejob, you are semi correct in the solution. I can't shift it manually to red line (shift point) because there is too much of a delay and it bangs off the rev limiter. So here is what works, Start the car in first gear, when it reaches ~4,000 rpm go ahead and shift to second (the car will automatically shift when it reaches it's set shift point in the tune of about 7000 rpm. once it gains traction in second you can go ahead and put it in 3rd or D and works like a charm. It's pretty sick barking 3rd gear at ~80mph in an Auto
Yes, once it gets traction you can shift up, if you had it in drive it would do the upshift downshift which is NG.
Your car sounds pretty fast, should be in the 12's, post some times if you get it to the track.
Have fun!!!
I think I see the stock 18's in your avatar, I had those. The stock tires suck, they would break loose on me if I hinted at driving aggressively. A better tire should solve your problem. I threw hankook ventus v12's on my car and now I can modulate the throttle on my launch pretty good and have no trouble on the 1-2 shift anymore (or the 2-3 anymore either haha).
I love this car.
I love this car.
I love this car.
I love this car.
2012GT, when you were stock...
From a stop, with TC on, how much wheelspin did you get on launch?
( no torque braking or anything, just flooring it)
This morning, I got a good bit, enough to put a smile on my face.
This afternoon, eh, a little.
The car would get traction pretty well. It would spin with the TC off but nothing like with a tune. The tune just makes the car sick bro. It breaks loose like a top fuel dragster now. I assume the torque management is bypassed etc in the tune. Just do it and quit putting your foot in the water. Jump in the lake man!
Yea the 235's aren't going to last long. They break loose like they're on ice with the tune and CAI. I'm trying to figure out what to do because I actually like the stock 18" wheels. Gus recommended 285/40 nitto DR's. Definitely want those for the track but not everyday driving. I'm kind of lost about what to do with the wheel / tire combo right now.
Just don't drive in them on the street below about 52 degrees; for that you will need dedicated winter tires (and perhaps dedicated wheels if you dont want to be paying someone seaonsally to swap/balance your tires). Alternatively you could use your all-season tires in the winter, but be aware that they are a compromise and won't stop you as quickly as the winter tires would.
Thank You! EXACTLY what I said earlier!! If you try to Manual Shift these cars in the 1/4 they will be SLOWER! Period!
Turboba6 (and others with Auto and tune), When you floor your car at highway speeds, will it sometimes drop to 3rd and then second after it decided 3rd wasn't low enough ? Mine does it sometimes depending on the speed (around ~60 mph).
It may have something to do with raising the rev limiter. But to explain... You're cruising along at highway speed - let's call it 65 - you go to WOT, the trans kicks down to 3rd with the motor pulling stongly for about 1 -2 seconds (perfect so far) then it kicks down again which instantly puts it at redline, so it has to immediately upshift. Very annoying.
