Prototype build and installed pictures 3" Dynomax exhaust (PICTURES)
I am Shauny Clause
MOTM July 2010 Winner
These photos are from The Dynomax prototype fabrication center here in MI.
They took my stock exhaust off the car and used a device called a Romer to create CAD data off of an existing part in order to create a 3" system that would have no clearance issues in the VERY tight area near the rear axle. The new CAD data is then sent to the fab shop where a tech uses those prints to create a prototype and thats what this photo series depicts.
here is a image of a romer for reference (image from google)
I dont have a sound clip yet, but its LOUD (like wake the dead loud). This is their Race Bullet setup. 3" mid-pipes and into a 3" axle back.
DISCLAIMER: their race bullet system is advertised as the loudest they make
and they tell you up front it will drone, if you want a non-drone system order their oval body mufflers.
Part #: 39505
Pricing is coming soon, available Feb 1, 2011 as they are now ramping up for a production run off the templates created on this build
Part #: 39505
Sweet set of pics! Those pipes are huge! I've heard this in person, and as Shaun says, it's loud! From inside the car it has a very unique tone, and it does drone at 1800-2100 RPM. From outside the car hearing the car pull away it sounds very "racy."
IMHO, so far all the exhausts I've heard for the Coyote all sound a bit "off." I can't explain it any better than that. Maybe I am just so used to hearing the older Mod motors, I don't know. But this Coyote just does not have that classic "Mustang" sound to it. It's more like a European V8, like the BMW, with a high-revving pitch to it.
I am Shauny Clause
quick question.....with your car on the ground with it being lowered is there plenty of clearance over the rear axle so the pipes arent hitting the axle? i only as because my magnaflow 3incher is hitting my axle. Evolution Perf has come to the conclusion that there is a prob with my kit and are supposed to fix it with a new kit on thursday when i have long tubes n x-pipe installed. I was just curious with your car how it is. thanks in advance.
I am Shauny Clause
Street trim
https://themustangsource.com/f726/co...ctures-485528/
Race trim
https://themustangsource.com/f726/up...y-park-485319/
this should give you a good start, I have hundreds of pictures of the car both on the road course and the street but this is a good start:
Street trim
Street trim
Well sir your going to be the Third twin then! After seeing his car i went and placed my order for a 2012 grabber blue 5.0 . And I hope stinger doesn't mind but I'm ordering that roush front fascia and painting it identical before the car even gets here! I hate that I have to copy someone to make my car look so jaw dropping but he did a hell of a job with the front end of his car
MOTM Committee Member
Lucky for you Shaun I like the Steeda fascia just as much
I am Shauny Clause
I now have audio clips of this from in the car, outside the car, partial throttle and full throttle gears 1-4.
problem, they are burried in audio files with 10 minutes of other crap. Does anyone know whwre I can find a free audio editing software that I can use to chop up this BIG clip??????
