Sponsored by:
Sponsored by:
painting the rusty rear end
Old Jun 15, 2014 | 10:22 PM
Mr. V's Avatar
OK. My title sounds disturbing but I've decided to paint the rusty rear end on my 12. Us pre 13 folks don't have the luxury of ordering the track pack to get one painted from the factory. I'm looking for paint recommendations as well as any tips. I appreciate any help that is offered.
Old Jun 15, 2014 | 11:13 PM
Ltngdrvr's Avatar
POR15 paint.
I plan to do mine eventually, probably when I finally get around to installing the control arms, will probably just pull it out of the car and do it right.
Old Jun 16, 2014 | 05:04 PM
14Glassback's Avatar
Originally Posted by Ltngdrvr
POR15 paint.
This!!! My friend painted the underside of his Fastback with this. Looks great and prevents further corrosion.
Old Jun 16, 2014 | 05:34 PM
Cobrakev's Avatar
Yep POR 15, best stuff on the market. Don't get it on yourself, takes forever to come off.
Old Jun 16, 2014 | 07:44 PM
Ltngdrvr's Avatar
Yeah, the POR15 paint seals the rusty surface from the air, so with no oxygen getting to it then no more oxidation can take place.
Old Jun 18, 2014 | 09:15 PM
NoSlo5oH's Avatar
Rustoleum primer and satin black spray paint worked great for me.
Old Jun 18, 2014 | 09:59 PM
Wasn't your TP axle painted from the factory?
Old Jun 19, 2014 | 01:06 AM
TommyV's Avatar
It's just surface rust. On copper or bronze, it would be called "patina." It doesn't hurt anything, and unless you're showing your car, with mirrors underneath, why bother?
Old Jun 19, 2014 | 11:57 PM
NoSlo5oH's Avatar
Yes, but it definitely wasn't true to Ford's old slogan; "quality is job 1." They didn't even prime the rear from the factory and it began to develope rust with 6K miles on the clock. My car and is always garaged, not driven in bad weather. Here's a pick of the factory paint job to show you how crappy it was.
Old Jul 1, 2014 | 07:06 AM
bodon's Avatar
One of the first things I did. Had 14 miles on my 2014. Was looking it over and noticed all the bare metal underneath. Put it up in the air and painted everything.
Old Jul 1, 2014 | 05:15 PM
Moejoe_989's Avatar
Wish I had know about that when I picked up mine!
Mine had 8,000 kms when I painted mine. It was RUSTY! It looked like the undercarriage of a 2011. I was ashamed to take it in for oil changes
I crawled underneath and used rust converter then black rustoleum paint. It's by no means professional, but it looks better than it did
Old Jul 5, 2014 | 10:01 PM
RubyRedMCA_Beast's Avatar
I think basing your opinion on Ford's quality on a painted axle is a little silly.
As with everything else, cost for 'extras' such as this are held as low as possible. I'm surprised they even paint the axle for TP models.
Old Jul 9, 2014 | 09:00 PM
NoSlo5oH's Avatar
Call it whatever you like bud, but for what they charge for these cars everything on them should be properly coated to help preserve the metals. Who want's to see their new car rusting within weeks of buying it?
Old Jul 9, 2014 | 10:37 PM
A) but for what they charge for these cars
B) should be properly coated to help preserve the metals.
A) Yet you want your 400+HP, and all your electronic gadgets, GPS/NAV because "I can't read a map", and your rearview camera because "I'm too lazy to look behind me first or look over my shoulder", for under $40k...
B) You really think the pumpkin and axle tubes are going to rust through in your lifetime? Or the cars lifetime?
Some metal experts on here will tell you that the rust is a protectant in an area of the car that is difficult to keep painted/treated.
My '83 F150 4x4 has 254k on it and rust on the rear end hasn't harmed anything.
But I wonder if the 2015 IRS will be painted for the "had to have it/don't know how to drive without it/pinky's up" crowd?
Old Jul 10, 2014 | 05:09 PM
NoSlo5oH's Avatar
[QUOTE=cdynaco;6826096]A) Yet you want your 400+HP, and all your electronic gadgets, GPS/NAV because "I can't read a map", and your rearview camera because "I'm too lazy to look behind me first or look over my shoulder", for under $40k...
A. I wanted more than 400HP, so I modified my car to satisfy my horsepower requirements. I don't have a GPS unit, nor do I want one. Yes I can read a map. I do have a camera though and use it in conjunction with looking over my shoulder. I'm definitely not lazy; the fact that I took the time to remove my rear end and have it painted properly should tell you that.
B. I never said the pumpkin or axle tubes would rust through in my car's lifetime, because I know they won't.
C. I don't have any intentions of buying a 2015, therefore I could care less if the rear end will come painted.
D. There's no need to snark at me bud, I just shared my opinion about the crappy factory paint job, as well as my pics and what worked for me in hopes of helping someone. Lastly, it's quite obvious that several other mustang owners are not happy with their rusty rear ends either.
Chuckin' up the deuces
Old Jul 10, 2014 | 08:32 PM
dave07's Avatar
I have a 2004 Ford Ranger Fx4 and the pumpkin was starting to rust through on the cover. There was an oil stain on the outside of the pumpkin and when I replaced the differential cover I could see the rust starting to penetrate on the inside.
Not really a big deal but it can happen. I had to get a new diff cover which was like $16.
The Ranger has 125k on it and is driven in the "salt belt".
Old Jul 11, 2014 | 11:39 AM
70monte's Avatar
It bothered me at first that the rear end and some of the other unpainted metal under the car was rusty, but as time goes on, I find I don't care as much. I don't normally drive this car in bad weather so I'm not too worried that it's going to get much worse. I may paint it at some point.
Wayne
Old Jul 11, 2014 | 01:26 PM
Mr. V's Avatar
Wayne
Lol. This is where my brain is now. When I started this thread, I had crawled under her to do some work and it drove me nuts. I've been busy and haven't gotten around to painting it. Now I'm not in a rush. I guess out of sight out of mine. Until I work on her again. .......
Ecostang
Nov 3, 2022 08:50 PM
oilmanlee
Sep 10, 2015 07:33 PM
Kev006
Jul 8, 2015 05:29 AM
