Oil Change to Royal Purple 5w-30
I'm sure it will work fine for you. But with the hundreds of thousands of miles I have put on Ford vehicles over 30 years - personal and commercial - following Ford factory recommendations for oil - I'm not going to do something different now just because of "internet stories". They have had different recommended oil over the years due to cast iron v aluminum block, improved engineering, testing, tolerances; OHC vs pushrod motors, now hydraulic actioned cams vs fixed cams. Not to mention improved oils from refiners and engineers. And the 4.6L motor has a fantastic record.
Please understand, I'm not challenging your personal decision. I'm challenging the internet rumor mill (mostly from oil guy bob) that Ford was willing to risk engine longevity and reputation with 20 v 30 just for the sake of any minute improvement for CAFE regs. That's a bull**** story.
Agreed. Use what you prefer. You have your reasons, I have mine.
I redline mine everyday. No carbon or cylinder ridge here.
I'm sure it will work fine. But with the hundreds of thousands of miles I have put on Ford vehicles - personal and commercial - following Ford factory recommendations for oil - I'm not going to do something different now just because of internet stories. They have had different recommended oil over the years due to cast iron v aluminum block, improved engineering, testing, tolerances; OHC vs pushrod motors, now hydraulic actioned cams vs fixed cams.
No sir you didn't. Its my understanding the engine block in a 2013 Ford sold in Europe is the same engine block and tolerances in a 2013 Ford sold in US. If its the same engine and tolerances then what engine oil in Europe is Ford recommending? What engine oil is Europe using in the same Ford vehicles as we have here?
The reason for multi-weights is to have thin oil which has low viscosity at start up, to ensure every spot gets flow at low temps, while maintaining viscosity at higher temps to ensure it continues to do its job of lubricating and cushioning clearanced parts.
Before multi-weight oil, one needed to choose whether to use light weight oil to do one or the other; not both.
I understand why going from 5/20 to 5/30 is beneficial. What I'm not sure about is if I should stick with a Synthetic-Blend (as installed & recommended by Ford), or go to a full-Synthetic (Mobil-1, etc.).
Anyone have any recommendations on changing from a blend to a full synthetic?
Will changing from 5/20 & a Blend to a 5/30 & full-Synthetic void the standard warrenty?
Just bought a 2014 5.0, only has 800 miles on it. Should I just drive it the 5000 miles w/the current 5/20 Blend? Or should I go ahead and switch out the oil to 5/30 (and a blend OR a Synthetic)?
These motors are already broken in at the factory before they hit the dealers lots. So the motor does not need to "bed" as you state. You need to get out of the 80's. Times have changed.
Mobil 1 is no longer a full synthetic. Hasn't been for many years. I along with many others run Amsoil 10w-30.
I'll trust my Owners Manual thank you.
True the Extended Performance is. But most people don't know the difference.
Go full synthetic, your choice on the weight. Just remember not all oils that advertise as being synthetic truly are.
These oil threads are always entertaining. I've learned a lot of stuff from these forums but what oil to use isn't one of them.
How many oil related engine failures on the stock engine have you seen posted in this or any other forum? I haven't seen any but maybe I missed one.
I have no more knowledge regarding oil than most of the people who post opinions about it but I do trust that Ford recommends the oil that provides the best performance in their engines and the oil that their engines are designed to use. If 5W-20 wasn't sufficient to protect the engine do you think Ford would use it? It defies logic. Corporations look at the bottom line and if Ford was getting excessive warranty claims they'd switch to a heavier oil so quickly it would make your head spin.
The often mentioned "fact" that they only use 5-20W for fuel economy may or may not be true but Mobil claims a 2% gain by switching to their 0 weight so it doesn't look like a switch from 30 - 20 weight will move the needle on the EPA meter enough to compel Ford to go with the lighter weight. Especially if it had the potential to harm the engine.
While I doubt switching to 5W-30 will cause any major problems why do it if it's not necessary? The OP states that his tick went away when he switched to a heavier oil. That makes sense and I assume that an even heavier oil would quiet the engine more. That doesn't make it the correct oil to use (and maybe it impacts the VCT) but I understand the logic. Running straight 50 weight would probably quiet the engine so much you wouldn't know it was running. One thing I'm fairly certain of - the tick didn't go away because the oil was manufactured by Royal Purple.
In my opinion any oil by a major manufacturer will provide excellent protection - even non-synthetic. I've always used Valvoline synthetic on my Mustangs. I could easily switch to Mobil, Amsoil etc but I started with Valvoline and will stick with it - brand loyalty - not because I think it's better than the other brands. I could also stay with the Motorcraft but I like the added protection synthetic offers if for some reason I'm low on oil and don't know it. Plus I think it keeps the engine cleaner.
If you really want to know how your oil is holding up go here.
http://tinyurl.com/yzh46m
They will perform a full analysis for not a lot of money and give you a detailed report on your oil including longevity. A good test would be to send them a sample from your original Motorcraft fill and then another after your second change. Then you'll have a basis for comparison rather than opinions.
This is from their FAQ.
What's the best oil to use?
Ah, the million dollar question. We are an independent lab, so we don't make recommendations. It has been our experience that oil is oil, and either petroleum or synthetic-based oil will work well for just about any engine.
Come on, you're holding out on me. I should use synthetic, right? Buddy, you should use whatever you want. Synthetic oil won't guarantee a longer engine life any more than my eating organic food will guarantee I'll live until I'm 90. We here at Blackstone generally use regular petroleum-based oil because honestly, it works just as well for us.
What's the worse can happen by using 5W 30 weight instead of 5W 20? I would imagine either weight would be fine but feel 30 weight just a hair thicker oil and 20 weight is like water. Lol
Great article . Using 5w 20 will reduce engine life by 30% compared to 5W 30
http://www.paladinmicro.com/documents/5W20Nyet.htm
The "money quote" from that article, the thing that seems to be the foundation of its conclusions, is this:
Originally Posted by http://www.paladinmicro.com/documents/5W20Nyet.htm
The ideal oil viscosity for motor oil used in conventional piston engine operating at the "normal" engine operating temperature is equivalent to SAE 30. (In range of 9 cP to 12 cP @ 100°C);
It is that very statement which is in question here. Just on its face, that statement appears to be vastly oversimplistic, with engine design tolerances being but one of the things that would call that statement into question.
Furthermore, it fails to recognize that many 30 weight oils will shear to a 20 grade oil or below.
The engine matters. The fundamental characteristics of the oil matter. Only experience will show whether the article is truly correct about the use of 20 weight oils in modern engines. If the average life of these engines drops (relative to their 30-weight-using brethren) due to internal wear, that will validate the article's conclusions. Little else will. There are too many variables in play here.
The nature of the machining on the engines has changed such that the break-in period is much shorter than it used to be (and/or the procedures are much closer to normal driving), but it hasn't been eliminated.
DerekShiekhi
Sep 30, 2015 06:59 AM
