Not many mods worth the $ on these cars?
I bought my car as a toy. It's not a DD. I just wanted a fast, fun car for the street. I'm not into 1/4 mile runs so most mods are not for me. I'll never use all of the factory HP so I'm not really interested in adding more. I added the Roush AB purely for the sound and not because I expected any HP gains. For now, the rest of the Mustang in factory trim is fine for me.
Wayne
Wayne
Snow tires if you live in a place like PA are worth the weight in GOLD.
Intakes are dyno proven (not butt dyno) to increase hp, sooo not sure how you could disprove that.
If you care at all about handling a watts link is a worthwhile upgrade, theres alot of room for improvement in the suspension
Alot of the things that people do are worthless, like putting on bigger wheels, or spring swaps, cams which rarely are tuned for properly. I can understand the hesitance towards tuners because there have been some issues with those.
As I recall...most runs it was over 90 degrees at O'Riley and the DA is almost always over 2300'.
Stock was 13.1s
Steeda Tune, CAI and shifter = 12.7s
NT05 added = 12.4@117 note these are the 275 street tire, not the DOT-Rs.
Tokicod, Springs, Control arms =12.1s. Average but best under 12.
Driveshaft. 11.9s very consistent but some under 11.8
The NT05 made the most improvement of my poor launches and 60' times which still need improvement and a shift light improved shift point consistency which helped keep most of my runs stay within 2/10ths of each other.
Now I have 295 rear tires -NT05Rs - so maybe we'll see better.
Not sure if the sway bars helps but those were added same time as springs.
Spring get here soon
Not at all - like it's been said earlier in this thread, this gen of Mustang has a very well designed stock intake that is hard to beat without a tune.
The difference is the MAF has to be recalibrated to take advantage of the larger area that the CAI gives you on the Coyote cars. This will add some HP but not what most would call significant enough to warrant the added cost of the CAI.
Also all dyno runs with these intake setups are done with hoods open giving them the advantage of more fresh air then they would have in a real world scenario. I remember reading threads about IAT's (intake air temperature) in CAI cars being much higher then stock. Yes they have heat shields but how effective are they really ?
So this begs the question of did I just spend $350 for a CAI to suck hot air and make little to no gain vs the factory setup ?
We all can weight the pros and cons of whether a mod is beneficial or not for ourselves... just wanted to add my $.02
The only cai I'd consider one day is the aem. It uses a dry flow filter and is fully enclosed with a scoop just like oem. It doesn't require a tune because the tubing is the same diameter. It also doesn't gain or loose power. But it looks amazing and matches so well it could have been factory.
MRGTX
2007-2009 Shelby GT500
Jan 2, 2024 04:30 PM
