Sponsored by:
Sponsored by:
New plugs on a 5.0
Old Aug 22, 2011 | 02:32 PM
Kona Blur's Avatar
Has anyone replaced the spark plugs on their 11? Any recommendations on a brand?
Old Aug 22, 2011 | 05:16 PM
2012GT's Avatar
Post this question in the s197 site. More technical site and modification knowledge there.
Old Aug 25, 2011 | 11:17 AM
Kona Blur's Avatar
I like that site alot now... Thanks
Old Aug 25, 2011 | 11:38 AM
S197 GT's Avatar
3rd Times A Charm
I did last weekend.
I used the Ford Racing One-Step Cooler plugs for my Whipple.
Really easy swap. 15 minutes tops.
Old Aug 25, 2011 | 11:39 AM
S197 GT's Avatar
3rd Times A Charm
*tips hat
Old Aug 25, 2011 | 01:53 PM
2012GT's Avatar
Originally Posted by S197 GT
*tips hat
Yeah, just found that site. Guys there aren't afraid of the ever fearful tsb and still mod their 5.0's lol.
Old Aug 25, 2011 | 03:26 PM
wproctor411's Avatar
Amen on that and Beefcake has some great info.
Old Aug 25, 2011 | 04:43 PM
S197 GT's Avatar
3rd Times A Charm
My info's pretty good too! Sheesh!
Have you seen my Whipple install write-up?
Old Aug 25, 2011 | 10:02 PM
Kona Blur's Avatar
I did last weekend.
Think I'm gonna go this route... Thanks bud
Old Aug 25, 2011 | 11:25 PM
S197 GT's Avatar
3rd Times A Charm
No problem.
Don't run a cooler plug though unless you are getting blown, turbo'd, or running nitrous.
Just get the factory heat range.
Old Aug 27, 2011 | 02:37 PM
Kona Blur's Avatar
Ordered... I'll get them on Monday... I'm having some spark knock in the Austin heat and I'm hoping this takes care of that **** noise
Old Aug 27, 2011 | 04:48 PM
2012GT's Avatar
Someone needs to do some dyno testing with wires and plugs among other simple things; I donate my car to Steeda for anything they want to try bolt on wise (ATTN GUS!!!) ...... When i had my 2001 SS, I changed the stock plugs when it was new to NGK Tr6's and TAylor vertex 10.4 mm wires. It was worth 6- 7 more to the rear wheels depending on the run. Amsoil was worth 4-5 rwhp over the stock oil but i didn't use it. There are big gains to made by simple things. We just need to test the Coyote with some simple stuff like this and find out what makes power and what doesn't as little as it may be. it all adds up.
Old Aug 27, 2011 | 06:05 PM
Kona Blur's Avatar
Does FR make a new wire kit for the coyote yet? And I should be ok running plugs a heat range cooler with no boost right? New stuff for me...
Old Aug 28, 2011 | 06:37 PM
zilla8's Avatar
You should not run the colder plugs unless you need to.The Ford Racing cold plugs are for use with a supercharger.You might actually lose performance running the cold plugs on a stock or bolt on N/A car.
Old Aug 28, 2011 | 08:08 PM
Kona Blur's Avatar
Should I get the boss plugs instead?
Old Aug 28, 2011 | 10:47 PM
S197 GT's Avatar
3rd Times A Charm
Hold on a sec...who's tune are you running? Your sig says SCT-93 Octane.
Are you running a canned SCT tune, or are you running a tune from BBR, Bama, Brenspeed, etc?
Have you been using octane booster?
Don't buy a cooler heat range plug for your current mod setup. Seriously!!
Old Aug 29, 2011 | 02:07 PM
Kona Blur's Avatar
I have a SCT tuner with a 93 octane tune that steeda loaded for me... Haven't swapped the plugs yet... Confused now...
Old Aug 29, 2011 | 02:39 PM
S197 GT's Avatar
3rd Times A Charm
So you have a Steeda tune, and the programmer (tuner as you call it) is an SCT device. The tune is from Steeda, you just use the SCT to load it into the vehicle.
Do not put the cooler heat range plugs in your car. They are made for a supercharged application.
When I originally replied to your thread, I mentioned my plugs and that they were for my Whipple.
I thought you might have had a question on how to read the plugs, or install questions.
I do not recommend or condone you putting those in your car.
What's making you think you have spark blow-out? Do you hear it, or are you datalogging?
Old Aug 29, 2011 | 03:56 PM
Kona Blur's Avatar
It sounds identical to the spark knock I had in my Durango a few years ago... I've got steeda looking into it now... Sent plugs back... PS: I'm a cartard so not sure what to do...
Old Aug 29, 2011 | 08:08 PM
drewzx3's Avatar
Sounds like you need to datalog and send to steedA.
