New Ford Performance oil separator.
![](https://themustangsource.com/forums/images/ranks/veteran_army.png)
The Bob's can is also easy to drain with it's bottom drain valve.. Where with Ford can, you have to practically uninstall it just in order to drain it..
In the meantime, I'll also be looking forward in reading Wayne's review as well..
Still have a hard time seeing why these are needed unless you are doing serious mods to your motor. I'm at 94,000 miles, burning little to no oil between changes and still getting power and fuel mileage like when it was new. No oil separator here.
The purpose of an oil separator, is to prevent crankcase oil vapors a.k.a blow by from getting past the intake manifold and into the combustion chamber..
When adding superchargers or turbos, this increases cylinder pressure which result in producing excessive amounts of crankcase oil that wind up getting pushed through the rings/valve seals into the upper intake manifold and combustion chamber via the OEM's closed PCV system..
With most N/A applications, the factory PCV system is designed to vent the crankcase through the intake manifold's vacuum port which evacuates the CC oil vapors into the upper intake to be burned off before ever having the chance to enter the combustion chamber ..
Therefore under normal cylinder pressures, there usually isn't anything to be concerned about, as small amounts of crankcase vapor oil are normal and won't enter the combustion chamber anyhow, as once again, the oil vapors end up getting burned off..
However when the amount of crankcase oil becomes excessive, it will get past the intake manifold and into the supercharger's internals/intercooler and finally into the combustion chamber itself..
Not only will this result in significantly reducing the supercharger's life for which you invested $5000.00+ of your hard earned money on, but also shorten your engine's lifespan in the process as well ..
With that being said, the purpose of an oil separator has nothing to do with oil consumption/oil burning whatsoever, but rather prevent contaminated crankcase residue from entering the combustion chamber, thus prolonging engine life !
Actually, any aftermarket tune pretty much requires one. I'm running the Ford Racing Trackey, which is about the tamest tune. I have incredible pinging from the fumes coming off PCV. So, you don't need FI and you don't need major mods. And it isn't all about cleanliness. It's also about actually getting the correct octane from the fuel by not diluting it with oil vapors.
Prior to upgrading to my current 06 GT.. I started out with a 2005 GT which for the most part was completely bone stock.. I then added a Steeda CAI with Doug's 93 octane race tune (bamachips) During the 7 years of running the bamachip's tune, I never encountered any crankcase vapor oil from the PCV connectors at the upper intake manifold whatsoever, as my car ran perfectly fine with no pinging issues..
The TracKey is a little unique because of the lopey idle and engine braking tuning, not so much because of the performance tune. Deceleration produces a lot of popping from the exhaust which can be unnerving and makes me want a separator. Also because Ford recommends it and because I can only get 91 here.
I have ordered the Ford Racing separator, but it has not yet arrived. I would not have believed I needed one either, but it's pretty bad over 4K with a hot engine. Noticeably better with fresh oil, and gets worse through the change period. I may switch from Motorcraft 5-20 to Redline full synthetic after receiving the separator. I'm really not building a racecar, but apparently the Trackey tune puts lots of timing in. Can't speak to the 2005 mentioned above. Reading on the forums, most (not all) 5.0's with a tune need it to take full advantage.
I am a TracKey owner as well... I spouse I should check the PCV connectors.
Perhaps the TracKey tune is more technically advanced and aggressive compared to the old 4.6 3 valves..
At any rate, I would most definitely check your PCV connectors at the upper intake between oil changes and would also add an oil separator for added insurance protection as well..
I really like the look and simplicity of the Ford can, but I also love the "reported" effectiveness of the Bob's can. Since I have neither at the moment, I lean towards the Ford model for simplicity of install and integrated looks.
Can't wait for Wayne to review the Ford can's performance.
I did make a small modification to the Ford separator since I had it open. I installed a stainless steel Scotch Brite scrubbing pad inside the holding chamber and molded it to fit inside to where it covers the inlet hole.
This setup is just like how the Bob's can is set up. The Ford's screen is finer than the Bob's perforated round diffuser so I'm curious if this modification will stop the oil film that I currently find. I'm going to run it about 500 miles and check my lines again.
Wayne
I finally opened my Ford Performance separator up the other day after about 300 miles and I had about 2mm of oil in it. I did have a slight film of oil in the connectors after the can but it was about the same as what I see with the Bob's can. It wasn't that much though since it barely stained a new Q-tip that I ran inside both connectors.
Wayne
Wayne
- Not nearly as good.
- Nearly as good.
- The same.
- Better
- Way better
As far as how does it compare to the Bob's can, it really is too early to tell because I only drove about 300 miles with the Ford can before I checked things. I typically ran the Bob's can around 1,000 miles before checking the amount of oil caught as well as what the exit lines leaving the can looked like. I never checked the Bob's can with only 300 miles on it so I don't know if it showed any signs of oil at that low mileage.
The fact that I don't see liquid oil inside the exit fittings is a good sign so at this point I'm going to say it's probably as good as the Bob's can.
The Bob's can has one advantage and that is the ease of emptying with it's ball valve. The capacity of the Bob's can is about the same as the Ford one. I think the Ford can has one advantage by being built out of plastic because it doesn't seem to get as hot as the Bob's can which a cooler can is supposed to help in the capture of oil.
The Ford can obviously looks more stock so that may be a consideration for some.
I may just run the Ford can for about 1,000 miles instead of the 500 to see what happens.
Wayne
Here is what kind of SS pad I used. http://www.walmart.com/ip/49260103?w...310514&veh=sem
Here is another link discussing this can. http://www.mustang6g.com/forums/showthread.php?t=46277
Wayne
Wayne
![Stirthepot](https://themustangsource.com/forums/images/smilies/stirthepot.gif)
Although they're not really required or necessary for N/A applications, adding an oil separator will most definitely help and also provide added insurance protection without a doubt as well..
Track Cal (same tune as Track Key) user here, adding the JLT separator did reduce the pinging under acceleration. I was skeptical before, thought these things were snake oil but turns out they actually do something useful.
An oil separator has nothing to do with the popping under decel, that's probably a side effect of the heavier engine braking in the Track Key/Track Cal tune.
I took a chance and ordered the Drivers Side unit (M-6766-A50S), figuring that if I could not make it work I'd sell it unmolested on fleabay.
With a small amount of modification to the unit and one hole drilled in the tab that was for the sound tube stay that I removed, it works and looks acceptable on my 2014.
#40
