Sponsored by:
Sponsored by:
Need suspension help!
Old Sep 23, 2011 | 02:20 PM
Rush1FiveO's Avatar
I purchased an Eibach Pro-Kit set, is it necessary to install camber plates along with the springs upgrade?
Old Sep 23, 2011 | 02:23 PM
AlsCobra's Avatar
A Man Just Needs Some....
Most people will tell you yes. And it definitely will make aligning it better. I'm lowered and don't have cc plates but you have to find a really good alignment guy to set it right. If you can swing for the cc plates, go for it.
Old Sep 23, 2011 | 02:35 PM
Rush1FiveO's Avatar
Thanks. I will definitely purchase them now. It was just confusing because the vids posted on AM showed only the springs being installed.
Old Sep 23, 2011 | 02:41 PM
Rush1FiveO's Avatar
Will the FRPP GT500 Style Strut Mount upgrade be sufficient?
AlsCobra's Avatar
Yeah, the cc plates just make life easier. I'm an alignment specialist and mine is aligned without them but I'll probably put some on one day.
Old Sep 23, 2011 | 06:27 PM
you can use camber bolts and save yourself some cash. With out a dobt. Ntb can do firestone goodyear and even sears stores that still have the auto centers can do it. NTB can do it without hurting your rims.
Old Sep 23, 2011 | 06:30 PM
The gt mounts are as good as the gt 500 mounts. You will not be able to tell the difference between the two. Well maybe in the price. Either way you will be fine.
Old Sep 27, 2011 | 10:40 AM
sam strano's Avatar
Hang on a minute here....
First, it doesn't matter how good the alignment guy is, the car does not have camber adjustment in it stock. Unless he's a magician, he can't adjust the camber with no other method added to facilitate that. All you can do is toe. And the car will have more negative camber in it when you add lowering springs, period.
You could do it cheap and use aftermarket camber bolts, I sell one set for $27.50 (http://www.stranoparts.com/partdetai...224&ModelID=35) And they do adjust camber to get it back in spec. But they are also small and hold much less torque than stock bolts, so I recommend other methods.
GT500 mounts have on adjustment, and are basically identical to the stock 2005-2010 mounts in any GT, just with a stiffer rubber part (which isn't what fails). So that's not going to help camber in the least.
I recommend two options. Either a set of adjustable mounts/camber plates. For street cars I like the Steeda HD mounts, and there is one specific to the 2011+ struts (http://www.stranoparts.com/partdetai...224&PartID=855) as well as for the older type struts, which currently ALL AFTERMARKET STRUTS ARE (http://www.stranoparts.com/partdetai...224&PartID=446) if you upgrade the dampers. Or keep the stock strut mounts, and use the Steeda billet camber adjusters: http://www.stranoparts.com/partdetai...224&ModelID=35
Old Sep 27, 2011 | 03:32 PM
BlackMamba03's Avatar
What about the Maximum Motorsports caster/camber plates? I've seen alot of the Boss owners install them and track their cars and have nothing but good things to say about them.
Old Sep 27, 2011 | 03:57 PM
wproctor411's Avatar
I use the Steeda HD mounts and they are great. I have MM plates on my 90' and they worked great too. It's nice to have even tire ware.
Old Sep 27, 2011 | 06:05 PM
06GT's Avatar
I have them, and of course they will work, but they are $340. They are very useful for adjusting between "street" and "track" camber settings.
However, if you just need to "set em and forget em", the bolts are probably the best (cheapest) way to go.
Also you could try elongating the upper bolt hole on the strut-to-spindle flange to let the spindle move towards the strut body more. This procedure is included in the FRPP handling pack kit as a way to increase negative camber to compensate for the included Pro-Kit springs.
Old Sep 28, 2011 | 11:12 AM
sam strano's Avatar
I also carry those... but I tend to keep those more for track cars, and the Steeda's I recommend more for street cars. The MM's use a spherical bearing that can make more noise than the Steeda mounts which use urethane bushings.
I'm not knocking the MM's. I sold 2 sets yesterday... I just think if it's a street car that the Steeda's are a better choice.
Old Sep 28, 2011 | 12:45 PM
Thanks for the good advice Sam. Once I get my suspension done, I'm going to be tracking so I'll be giving you a call for the MM plates.
Old Sep 28, 2011 | 05:51 PM
SAM is THE MAN
Old Sep 29, 2011 | 01:54 AM
Rush1FiveO's Avatar
Ahhh dangit man... I just purchased the eibach bolts this morning, thinking it would be sufficient. gotta go back in and cancel the order asap. Thanks Sam for the input!
Old Sep 29, 2011 | 10:00 AM
Bolts = no beuno in my book. Plates are the way to go.
Old Oct 31, 2013 | 04:03 PM
Music man in Pcola's Avatar
I had Steeda UltraLite springs and Steeda HD upper strut mounts installed in my 2012GT and the best alignment specs I can get equals -1.3 camber with the stock bolts installed. I have a set of Eibach camber bolts and wonder if I should have them installed as well to get a slightly less aggressive alignment...even though I love the handling. I do expect more rapid tire wear.
Old Nov 1, 2013 | 05:59 AM
Bocefus's Avatar
worked for me
robjh22
'10-14 Exterior Modifications
Oct 9, 2015 02:49 PM
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
samjluck
Sep 17, 2015 10:24 PM
Evil_Capri
Sep 11, 2015 08:39 AM
