Need suspension help!
Most people will tell you yes. And it definitely will make aligning it better. I'm lowered and don't have cc plates but you have to find a really good alignment guy to set it right. If you can swing for the cc plates, go for it.
Originally Posted by Rush1FiveO
Thanks. I will definitely purchase them now. It was just confusing because the vids posted on AM showed only the springs being installed.
you can use camber bolts and save yourself some cash. With out a dobt. Ntb can do firestone goodyear and even sears stores that still have the auto centers can do it. NTB can do it without hurting your rims.
Hang on a minute here....
First, it doesn't matter how good the alignment guy is, the car does not have camber adjustment in it stock. Unless he's a magician, he can't adjust the camber with no other method added to facilitate that. All you can do is toe. And the car will have more negative camber in it when you add lowering springs, period.
You could do it cheap and use aftermarket camber bolts, I sell one set for $27.50 (http://www.stranoparts.com/partdetai...224&ModelID=35) And they do adjust camber to get it back in spec. But they are also small and hold much less torque than stock bolts, so I recommend other methods.
GT500 mounts have on adjustment, and are basically identical to the stock 2005-2010 mounts in any GT, just with a stiffer rubber part (which isn't what fails). So that's not going to help camber in the least.
I recommend two options. Either a set of adjustable mounts/camber plates. For street cars I like the Steeda HD mounts, and there is one specific to the 2011+ struts (http://www.stranoparts.com/partdetai...224&PartID=855) as well as for the older type struts, which currently ALL AFTERMARKET STRUTS ARE (http://www.stranoparts.com/partdetai...224&PartID=446) if you upgrade the dampers. Or keep the stock strut mounts, and use the Steeda billet camber adjusters: http://www.stranoparts.com/partdetai...224&ModelID=35
However, if you just need to "set em and forget em", the bolts are probably the best (cheapest) way to go.
Also you could try elongating the upper bolt hole on the strut-to-spindle flange to let the spindle move towards the strut body more. This procedure is included in the FRPP handling pack kit as a way to increase negative camber to compensate for the included Pro-Kit springs.
I'm not knocking the MM's. I sold 2 sets yesterday... I just think if it's a street car that the Steeda's are a better choice.
I also carry those... but I tend to keep those more for track cars, and the Steeda's I recommend more for street cars. The MM's use a spherical bearing that can make more noise than the Steeda mounts which use urethane bushings.
Thanks for the good advice Sam. Once I get my suspension done, I'm going to be tracking so I'll be giving you a call for the MM plates.
I had Steeda UltraLite springs and Steeda HD upper strut mounts installed in my 2012GT and the best alignment specs I can get equals -1.3 camber with the stock bolts installed. I have a set of Eibach camber bolts and wonder if I should have them installed as well to get a slightly less aggressive alignment...even though I love the handling. I do expect more rapid tire wear.
Evil_Capri
Sep 11, 2015 08:39 AM
