Sponsored by:
Sponsored by:
My 2013 GT Crazy Canadian Build thread
Old May 25, 2014 | 11:23 AM
  #41
Mikey's Avatar
This is the hood I want to get eventually... Looks beautiful and mean at the same time!
Old May 26, 2014 | 04:17 PM
  #42
DarrenGT's Avatar
installed my shifter ball from CJ pony parts. Has a very nice weight to it.
MGW is on the list but for now, this helps
Old May 29, 2014 | 11:43 AM
  #43
DarrenGT's Avatar
I am considering this suspension package. I have been after some kind of adjustable system all along. Adjustable rear ride height especially appeals to me.
2 Single adjustable, custom valved Konis in Ground Control short strut housings
2 SHORT Koni single adjustable rear shocks
1 Pair front Camber Plates
4 Ground Control springs, manufactured by Eibach, to GC specs
2 Ground Control bump stops (made in Germany)
2 Rear Ride Height Adjusters
1 Pair rear upper shock mounts (urethane)
I am currently running the Eibach Pro kit springs and PHB which have lowered my car about an inch. I have noticed alot of comments around LCA's and UCA replacements. what are they and why replace them?
Thanks guys
Old May 29, 2014 | 12:07 PM
  #44
Mikey's Avatar
Thanks guys
I'm also considering the ground control coilover kit, so hopefully someone can provide some insight.
The reason for LCA and UCA replacement is to reduce wheel hop due to the deflection in the stock pieces, mostly due to the bushings. In addition, once lowered the adjustability from an aftermarket UCA and LCA (assuming you buy the adjustable ones) will help to maintain proper suspension geometry and pinion angle. Btw, I'm no expert. There are many resources to talk to when considering suspension, I'm sure one will chime in.
I'd talk to Jay and/or Dan from Hypermotive when you're ready to purchase, they have great pricing and the best customer service. I only mentioned this because I'm assuming you found the ground control coilover kit on their site.
Old May 29, 2014 | 12:12 PM
  #45
DarrenGT's Avatar
yes Jay and Dan have been helpful.
btw…
DYNO next tuesday
Old May 31, 2014 | 09:38 AM
  #46
DarrenGT's Avatar
Next week is a big week…
Dyno Tuesday for a baseline, then off to body shop to have the shelby front painted and installed, the spoiler done, the hood clear coated. Then a couple weeks later put the stripes back on.
August will see some really big mechanical enhancements depending on bonus check of course!
This is what I am after looks wise, but blue of course.
http://www.autogespot.com/ford-musta...012/03/26#img1
Old Jun 3, 2014 | 07:46 PM
  #47
DarrenGT's Avatar
took her to a dyno for a baseline today. And so begins "Project Black Mamba Convertible"
Old Jun 3, 2014 | 08:23 PM
  #48
DarrenGT's Avatar
here's the vid.
342 rwhp and 323 torque. Untouched bone stock motor on cheap gas and factory program.
https://drive.google.com/file/d/0B5Q...it?usp=sharing
Old Jun 7, 2014 | 12:28 AM
  #49
DarrenGT's Avatar
sadly the CF hood is not good. It came with some cloudiness to it that the body shop could not remove. My research into the cloudiness indicates something went wrong at manufacturing. possible UV inhibitor, bad batch of resin or perhaps delamination.
I'll wait and see what BMC says.
Old Jun 7, 2014 | 09:09 AM
  #50
sadly the CF hood is not good. It came with some cloudiness to it that the body shop could not remove. My research into the cloudiness indicates something went wrong at manufacturing. possible UV inhibitor, bad batch of resin or perhaps delamination. I'll wait and see what BMC says.
It's always a risk when buying a large CF part. If it fits well, I'd just do the DIB Clearcoat like I mentioned and never look back!
Old Jun 7, 2014 | 10:16 AM
  #51
I'm more than positive that is case. I hope they take care of you Darren.
Good luck!
Old Jun 7, 2014 | 11:09 AM
  #52
DarrenGT's Avatar
They did say that it's the best fitting CF hood they'd ever seen LOL. It does fit remarkably well. For now, i'll just wait and think about what to do with it. At some point i may put the stock hood back on for a couple of big mustang meets coming up. not sure. No more $$ to put into it for now.
Old Jun 10, 2014 | 09:46 PM
  #53
DarrenGT's Avatar
well after a couple days of research, no further word from BMC, and discussions with the paint tech, the body shop and other body shops, i've decided that maintaining clear coated CF is a pain in the **** and not worth it. We are going to paint it to match the car, leaving only the vents in CF. Tomorrow she goes in to become DIB Black Mamba.
Old Jun 10, 2014 | 10:44 PM
  #54
DIB clear!!! Possible?
Old Jun 10, 2014 | 10:47 PM
  #55
DarrenGT's Avatar
no unfortunately, the cloudiness would continue to be a problem. I'm fine with painted. never wanted a CF hood in the first place. just happened that way.
Old Jun 10, 2014 | 11:07 PM
  #56
Ah well, at least you got the beefy looks!
Old Jul 17, 2014 | 12:13 PM
  #57
DarrenGT's Avatar
some updates…
ordered the ground control coilover and spring kit from Dan at hypermotive today. excited to finally have some more control over the suspension. the current suspension has been pissing me off more and more.
Old Jul 17, 2014 | 12:24 PM
  #58
DarrenGT's Avatar
CF hood painted and striped. Black mamba hood from BMC. The heat extractors were left unpainted. You can see the CF pattern through the DIB under direct sunlight from certain angles, otherwise the paint is a perfect match.
Old Jul 17, 2014 | 12:25 PM
  #59
DarrenGT's Avatar
new oem bumper and siebon cf grills get installed with new oem spoiler on monday
Old Jul 17, 2014 | 04:01 PM
  #60
Very nice Darren.
