Sponsored by:
Sponsored by:
MUSTANG NITROUS KITS
Old Mar 5, 2015 | 04:13 PM
jcsix13's Avatar
who makes the best nitrous kit for a 5.0? how long will a 10lb bottle last on the street?
Jack
Old Mar 5, 2015 | 10:49 PM
Moejoe_989's Avatar
This largely depends on the type of nitrous kit and jetting used. For a NX system, the calculation is .8lbs for every 100hp per 10sec. So if you are spraying 100hp you should be able to get 6-8 good 10 sec. runs out of a bottle.
If you have a 10 LB bottle you'll get 120 seconds of nitrous at 100 HP. If you run it at 75 HP, you'd get about 3 minutes.
It's usually suggested you don't run the nitrous for longer than 15 seconds (usually one run down the 1/4) as this can melt the solenoid magnets.
So 15 second bursts. 10 runs maybe?
Hope this helps!
Old Mar 6, 2015 | 06:39 AM
2012GT's Avatar
Hope this helps!
Good info
Old Mar 7, 2015 | 06:29 AM
jcsix13's Avatar
Hope this helps!
thanks for the info
now to figure out who makes the best kit
Old Mar 7, 2015 | 06:59 AM
Zex has been around a long time and have always been pretty good units as far as I know.... To be clear, I know very little
Old Mar 7, 2015 | 07:51 AM
2014GHIGGT's Avatar
X2 to ZEX ;-)
I have had good luck with their kits in the past.
I am not certain if folks use wet or dry kits on these new 5.0's
I know on the old 5.0 (my era) we used dry kits as the fuel would puddle up in the intake manifolds. I am not certain if that is the case with these new 5.0's
Old Mar 11, 2015 | 05:41 PM
2012GT's Avatar
The NOS dry kits are what we all ran in the early 2000's in our 4.6 & LS1 cars . Great systems and relatively easy to install. Back then the Zex kits had a lot of issues . I guess they're corrected now. If I ran nitrous again, I'd go back with NOS though. Nitrous isn't as common as it was. Everyone had nitrous in the early 2000's . It's not remotely as popular now.
Old Mar 11, 2015 | 07:03 PM
cleangraystang's Avatar
Which ever kit you go with remember nitrous is for the track not the street its against the law to have a active nitrous kit in your car on the street.. And they will really come down on you if you get caught....
Old Mar 11, 2015 | 09:46 PM
ElkGroveFordGuy's Avatar
I always ran nitrous express kits!
I also recommend a wet kit they make more power safer!
Old Mar 11, 2015 | 10:01 PM
2012GT's Avatar
That is an incorrect blanket statement. It is perfectly legal in South Carolina. As for other states, some are the same as South Carolina.
Old Mar 12, 2015 | 05:45 AM
SpectreH's Avatar
Didn't Ford sell a Saleen N2O Focus in the early 2000's straight off the dealer lots?
killaz05
Jul 24, 2015 08:49 AM
AMWill
Jul 20, 2015 08:40 AM
