MGW Race Spec and Blowfish bracket
I still get lockout every now and then (usually cold), so I definitely need to try a new fluid.
I don't get lockout, just some notchiness when cold, but no grinding anymore, thank goodness. That's why I'm doing fluid when she comes out in spring. You doing RP or something else?
Maybe I don't need a shifter as badly as I thought.
On a side note I just picked up an aluminum Shaftmasters driveshaft as part of their Black Friday deal. I like the idea of the driveshaft safety loop that the Blowfish bracket provides.
Is the solid shift rod that big of a deal? I know it is with the race spec MGW because they use it as a second mount point. With the MGW rev 1 and the Blowfish bracket its not supporting anything. Makes me wonder if its some hype on MGW's part but in reality its just needed in their design to work properly. I also know some have a lot of weld slag on their factory shift rod and may feel the need to replace it but mine was perfectly smooth from the factory.
Initially my shifting was audibly crunchy, and really bad when the car was cold. When fully warmed up, it varied between notchy and crunchy, and quick shifts just weren't in the cards no matter what. I started with the Energy Suspension bushing as a $15 test to see what effect it had. It made the car driveable when cold and a decent improvement when warm as long as my own technique was dead bang on in terms of timing. Putting the MGW in was a night and day improvement. It made it "a bit notchy" when the car was cold, and nice and smooth and positive when the car was warm, even when hustling it and shifting quickly. At this point, just improving cold lubrication is really all I've got left to do.
Not sure...need to do the research. I still get crunchy shifting and I've ground 5th and 2nd a couple times. With the MGW, I really have to pull towards me to grab 2nd consistently, and really have to shove up right for 5th...
I've tried a lot of shifters/bracket combos. Including the bf bracket with a tri ax shifter. The bf bracket is good but I wanted something with less nvh. The new mgw is by far, the best available. And it's cheaper than and shifter/ bf bracket combo out there. Unless you keep the stock shifter.
I'm loving this new MGW race spec! After watching the video, this may be the push I needed to finally get one. The design looks very sound to me, and I like their reasoning for using the bracket as a damper.
Now will the 2014 version come with the option of getting the 2015 shift know? It looks really cool.
I just wanted to post and clarify a few things because i feel you are off base just a bit on the design of my shifter...
The linkage ( pivot ) rod is not intended as a support piece , i was just stating that BECAUSE it actually is a top loader concept i.e. rod coming straight out of the trans..then it actually provides even more stability.
I know its going to take more and more guys actually getting this race spec in their hands to understand just how rigid it is. i COMPLETELY put it up against any bracket or design and stand that it is just as rigid if not more. Plus... with the engineering i have done in the whole shifter assembly, NVH is minimized greatly!!
I keep hearing over and over and over ( not from you ) that our shifter STILL attaches to the body and thats why its not as rigid but i just cannot stress enough that this in ONLY for NVH!!!! we tried the shifter with and without and the rear bracket design technology really really works to absorb vibration.
George
George
I just wanted to post and clarify a few things because i feel you are off base just a bit on the design of my shifter... The linkage ( pivot ) rod is not intended as a support piece , i was just stating that BECAUSE it actually is a top loader concept i.e. rod coming straight out of the trans..then it actually provides even more stability. I know its going to take more and more guys actually getting this race spec in their hands to understand just how rigid it is. i COMPLETELY put it up against any bracket or design and stand that it is just as rigid if not more. Plus... with the engineering i have done in the whole shifter assembly, NVH is minimized greatly!! I keep hearing over and over and over ( not from you ) that our shifter STILL attaches to the body and thats why its not as rigid but i just cannot stress enough that this in ONLY for NVH!!!! we tried the shifter with and without and the rear bracket design technology really really works to absorb vibration. George George
call them. The are offered a $200 core exchange. They give you 30 days to return the gen 1.
