Which LCA's to get
I'd recommend the FR500C arms. Race proven and at $209 retail it's pretty hard to go wrong.
On a different subject........
Can someone tell me what would stop the lower control arm mounts pictured below from rotating around the axis of the attaching bolt allowing the LCA to move back and forth? Seems like a very poorly executed design.
There is a part that goes inside the mount on the axle that is also bolted on.
http://www.cheperformance.com/CartGenie/prod-311.htm
Soflo5gt. I like your setup. Are those CHE squat brackets the same as relocation brackets and do they work better and do the same? Also most people are saying to weld them in, there's a thread on svtperformance where UMI relocation brackets busted from either not welding or the product failed. And did you paint them blue? Thanks
