Sponsored by:
Sponsored by:
JLT OIL Catch Can gains?
Old Aug 13, 2011 | 07:43 PM
2012GT's Avatar
I completely understand what it does. However, has it has shown any definitive performance gains by adding a pony or 2?
Old Aug 13, 2011 | 07:55 PM
DaSFGiants4Life's Avatar
No, it just catches oil. It can preserve the engine longer.
Old Aug 13, 2011 | 08:07 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
correct.
it has no ability or way to add power
Old Aug 13, 2011 | 08:29 PM
Vectors2Final's Avatar
The only "possible"- "gains" you could ever get from an OCC is the lack of blowby in the system decreasing your octane levels and causing DET.
The mods you have listed barely warrant an OCC, but should you go FI, or do a full NA build, then you will have plenty of benefits because the blowby isn't robbing you of "power" as is more prevalent in FI setups.
Old Aug 13, 2011 | 08:35 PM
2012GT's Avatar
Thanks Vector. That is what I assumed. I only wondered because by always keeping the octane level consistently at it's peak by not allowing any blow-by in the intake. Therefore, possibly showing an additional HP or 2 on the dyno.
Old Aug 13, 2011 | 09:42 PM
hawkeye18's Avatar
It gets you zilch on the dyno. It will, however, give you a net gain in about 100,000 miles, as without the catch can, in that time the intake will be so coated in oil that you will lose quite a few horses on the dyno. The catch can will prevent you from losing those.
So in a way, sure, it'll get you power - just not now.
Old Aug 14, 2011 | 02:51 PM
Unless he went FI, then he'd see the benefit a lot sooner than 100k.
Old Aug 14, 2011 | 04:37 PM
By which the ECU would pull timing and/or richen the A/F, both robbing a bit of power.
But I'm into the longevity aspect for my NA.
Old Aug 14, 2011 | 04:45 PM
mystickeith50's Avatar
Get it! For 119 bucks you can't beat the purpose of it. Put it on, go out a beat up on your car for an hour, check out the oil in it, and then say Holy Batcrap why didn't I buy one of these a month ago.
Old Aug 14, 2011 | 07:13 PM
montreal ponies's Avatar
Love opening up my catch can and see the oil that got caught.
Old Aug 14, 2011 | 07:19 PM
hawkeye18's Avatar
Well, sure, but I was being conservative.
Old Aug 14, 2011 | 08:28 PM
^Understandable.
I was trying to keep it simple.
Bryanh24
Oct 14, 2015 08:43 AM
RoushRS3
Sep 29, 2015 08:03 PM
GLOCKer
Sep 28, 2015 05:20 PM
southern stang
Sep 26, 2015 04:19 PM
