Sponsored by:
Sponsored by:
JHR Clutch line install ???
Old Jul 28, 2012 | 08:33 PM
t-fatty's Avatar
I got a JHR braided steel clutch line that i'm hoping solves the clutch pedal dropping. What do i need/how do replace/bleed the system after install?
Old Jul 28, 2012 | 10:06 PM
LEwis26's Avatar
The clutch is self bleeding. You just need to pump the pedal a few hundred times.
Old Jan 8, 2013 | 06:02 PM
Nocturnal'14's Avatar
Didnt want to start a whole new thread...so I brought this one back from the depths!
Well in regards to the clutch line....all I can say is I LOVE IT!! Installed mine tonight (20min tops) and it did exactly what I was hoping for....got rid of that **** 1-2 crunch! Sooo very smooth. Had a little trouble with install, the lower portion with the 90deg angle. The clip that attaches the 90 to the trans got a little twisted and my dumb @55 installed the clip 180 deg from where its supposed to be. So fingers crossed I dont ever have to change it!
As stated be sure you check the fitting ends before install...I had to tighten mine too!
PICS!
UPPER PORTION:
LOWER 90 deg bend:
Old Jan 8, 2013 | 10:28 PM
Ponywars's Avatar
Did you have to bleed it?Where did you order the line from?
Old Jan 8, 2013 | 10:29 PM
Ponywars's Avatar
Tfatty how do you like the hankooks?
Old Jan 9, 2013 | 05:14 AM
ordered it straight from Joe Heck Racing Store....
The newer cars do not have a valve for bleeding, it is self bleeding. SO, all you have to do is press the clutch about a 100 times (Literally) the first 50 or so it will get stuck to the floor with spring pressure, just pull it up with your hand.
Old Jan 9, 2013 | 06:29 AM
SoFlaBoss's Avatar
I still have a brand new JHR high volume clutch line that I meant to install on my 2012 Boss, that I bought from Lethal Performance. However, I traded-in my Boss. If anyone's interested, then please send me a PM. It's brand new in its original packaging.
Old Jan 9, 2013 | 06:42 AM
wheelman's Avatar
PM sent
Old Jan 9, 2013 | 09:11 AM
SoFlaBoss's Avatar
Originally Posted by wheelman
PM sent
replied
Old Jan 9, 2013 | 09:14 AM
wheelman's Avatar
replied
Thank you, but Ill pass for right now so its still up for grabs. A part Ive been waiting for just became available on AM so Im gonna grab it. Will check back to see if still available when I get more $.
Old Jan 9, 2013 | 09:53 AM
SoFlaBoss's Avatar
Thanks. I posted it FS in the thread below priced a little lower after viewing what they sell for now on Lethal's site.
https://themustangsource.com/f722/fs...6/#post6527017
Old Jan 10, 2013 | 07:17 PM
djstorm100's Avatar
What fluid do you use for the clutch dot 4?
Old Jan 11, 2013 | 06:36 PM
Correct.
Old Jan 14, 2013 | 02:21 PM
Mustang259's Avatar
Will this mod help a 2013 ?
I have read that 12's had the problem but not much on the 13"s
Old Jan 14, 2013 | 03:12 PM
wheelman's Avatar
It happens in at least some 13s b/c mine does it, but the sticking issue is with a spring. This might help with clutch feel and response, though. Im gonna try it soon but had to grab an oil cooler that just became available again and Im a man of meager means.
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
stewarts359
Jul 21, 2015 03:39 PM
Kgilly
Jul 9, 2015 01:47 PM
