Help! One Borla muffler one inch lower than other.
I have the Borla Over axle pipes and S Type ABs. My driver side AB sits about 1 inch lower than the passenger side. I have played with the over axle pipe and the mufflers, but they dont seem to to change where they rest. Any thoughts or ideas? Maybe new hangers will fix the problem?
Wanted to see if anyone else had this same issue before i spent $80 on new hangers.
Edit: Fixed the problem. Took everything off the car. Slightly bent the hangers on the mufflers so they were about the same measurements. This took a while because I had to make sure they could go back into the hangers properly. Finally, once everything was bolted up, I just bent hanger rods around until the tips were equally centered. Hope this helps anyone who has the same issue.
Dubl10
Sep 13, 2006 07:11 AM
Dubl10
Aug 31, 2006 07:42 PM
roadracer
05-09 Exterior Modifications
Nov 26, 2005 08:13 PM
