Sponsored by:
Sponsored by:
Going from one tune to another- reset to factory first?
Old Apr 15, 2015 | 09:50 PM
Varilux's Avatar
The Steeda CAI / Bama tune package FINALLY came back in stock at AM (been waiting a month), so I took the plunge and should have everything here over the next week.
My question pertains to switching tunes. Currently, I have the Ford Racing Procal tune installed (and I still have the Procal unit, which I believe has my stock tune backed up on the chip).
So, when I go to install the Bama tune, should I reload the factory tune from the Procal first, or just load the Bama tune over the Ford Racing tune? My understanding is the tuning device will store the tune that is currently on there (which would be the Ford Racing tune) before installing the Bama tune. I don't plan on getting ride of the Procal tool, so I guess I would still have the factory tune there if I ever needed to go back to stock, correct?
BTW, I thought the tuning device was the X4, but it turns out it was a Diablo- the fellow at Bama was happy to switch me to the X4, and I'm looking forward to seeing how the 93 octane Bama racing tune performs.
Old Apr 15, 2015 | 10:01 PM
Enfynet's Avatar
I would always return to stock before loading a new tune.
Old Apr 15, 2015 | 10:03 PM
ElkGroveFordGuy's Avatar
Did you ever dyno your car or run it at the 1/4 mile?
I would love to hear a true side by side comparison, from a non biased customer.
Old Apr 15, 2015 | 10:23 PM
trizzot's Avatar
I just updated my tune to Bamas V2 tune. My directions were to reinstall the stock tune before loading the new tune. I also have the Steeda CAI, and Bama V2 tune. Im thrilled with both.
Old Apr 16, 2015 | 08:22 AM
zeroaviation's Avatar
You do NOT have to install the stock tune before loading the new tune. Its a waste of time.
Should I get technical?
-Matt
Old Apr 16, 2015 | 09:29 AM
Joeywhat's Avatar
-Matt
Sure.
Not that I don't believe you... But why not?
Old Apr 16, 2015 | 10:12 AM
I was told by AM that it is not necessary to go back to stock when changing tunes.
Old Apr 16, 2015 | 10:27 AM
Originally Posted by Joeywhat
Sure.
First READ THIS
When you are uploading a tune, you are just replacing a portion of the firmware in the ECU. When the upload process is complete, the ECU is reset.
If you were to load the stock tune in first, it would just end up getting replace byte by byte with the new tune. Nothing else changes.
Therefore, its not needed
-Matt
SpectreH's Avatar
The only reason I can see to go stock first is if you are using a different tuner altogether and want to unlock the installed tuner before using the next one.
Old Apr 16, 2015 | 08:34 PM
Varilux's Avatar
Whoa- you lost me... I think. By "unlock," do you mean return the tuner to a state where it can be used on another car? As mentioned, I still have the Procal Tuner (it doesn't seem to let you do much, but I figured I could at least read/clear codes with it if the need ever arose). I'll be going to the SCT X/4 (or whatever its called) tuner to load the Bama tune.
My presumption is when I go to load the Bama tune, the new device will store the tune it is replacing (which is the Ford Racing Procal tune). Since the Procal was installed at the dealer, all I ever need to be able to do is return to it- not the factory tune.
Old Apr 17, 2015 | 04:45 AM
Leosim's Avatar
Just picked up my 2015 5.0 last weekend. Is there a tune kit for this vehicle yet?
Old Apr 17, 2015 | 05:56 AM
tom281's Avatar
Yep..... search the aftermarket, there are many companies offering tunes. Also checkout the 2015 forum.
Old Apr 17, 2015 | 06:19 AM
SpectreH's Avatar
That is exactly what I meant.
Old Apr 18, 2015 | 06:20 AM
BLK STANG's Avatar
I was told that it is necessary to return to stock every time you want to upload a new tune, and that's what I will be doing once I switch tunes.
Old Apr 18, 2015 | 08:33 AM
Did a big name tuner tell you that?
Its not necessary.
Old Apr 18, 2015 | 11:12 AM
Cavero's Avatar
-Matt
^^ this. I've never returned to stock in between tunes for the last 7 years and have never had a problem.
Old Apr 18, 2015 | 06:04 PM
Varilux's Avatar
One other question (well, one of many I'm sure)...
When I filled out the form with Bama, I didn't need to enter my VIN- just the four digit code off the ECU. When I ordered the tune from Ford Racing, I needed both the ECU code and the VIN.
Why doesn't Bama need the VIN? Will the VIN imprint itself on the tuning device when I hook it up (I think these things usually set themselves to work only on the car they are hooked up to)?
Old Apr 21, 2015 | 02:33 PM
choate's Avatar
Before I had to talk to SCT I never went back to stock first. This last time I went to update the device and it locked. I called them and the first thing he asked is "did you return the car to stock" and I said not I haven't messed with the car yet, just trying to update the device. The thing is though and he explained the stock tune was on the locked device. He said I may have to pay $150.00 for them to unlock it to get the stock tune. Long story short he said always return to stock first so that's what I did and of course it worked after they straightened out all the other technical issues I was having. I will probably always go back to stock first now just to be safe if they ever ask when something goes wrong. It says everywhere on their site, in the email from Bama etc to go back to stock first and he mentioned that to me. Either way it won't hurt it if you don't but if the transfer fails then you could run into problems possibly. That's my $0.02
Road_Runner
Sep 2, 2024 04:46 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
samjluck
Sep 17, 2015 10:24 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
