Is getting the Roush calibration a dead end for future tuning?
I'm getting a Roush stage II kit installed this upcoming week and my plan was to go with the Roush factory calibration (send the ECU to Roush) for now. I was just reading on a chat board that if you go with the Roush calibration you cannot later get a SCT tuner and a tune because aftermarket tuners cannot read the Roush calibration. Anyone know if this is true? I hate to think that if I'm not happy with the very conservative Roush tune that I could not go another route later on.
The tuners would only need to read the Roush tune if they were trying to modify it, but if they just write a new tune then the Roush tune isn't needed anymore.
The thing you won't be able to do is return to the stock tune if the blower was ever removed, because you won't have the stock tune saved anywhere. If that ever became the case you would have to have a Ford dealer flash a stock tune back onto the pcm.
Thanks to all for the replies, good to know that I'll be able to put an aftermarket tune on if (and do to my mod disease probably will) I don't feel the around 550 RWHP isn't enough. I'll have some before and after dyno pulls to post up.
I have the 575 hp kit, bassani catback, i have the stock 3.31 gears and a dss driveshaft. got justin at vmp to tune it via data logs. 557 rwhp 461 tq.
If I end up selling it for a roush rs3 or a Shelby ill definitely be getting Justin to tune.
OP: I did this exact thing you are referring to....Phase 2 kit w/ROUSH Calibration.
That lasted all of a month and I wanted more...so I installed a VMP 82mm pulley (10.5psi) and a custom tune form Justin. Do yourself a favor and get better tires before getting it custom tuned (theres a reason the stg3's only come with a 275 wide tire) the stock ROUSH Calibration is pretty darn rich!
With Justins tune it is night and day and you WILL burn off the tires!!!
If I had to do it all over again I would just get the VMP TVS Pkg!!! Better HE, injectors , tune and power!!!
Did you do a dyno on your current setup and if so what are you pulling?
Is the 82mm pulley something you put on yourself?
What are you doing for a fuel pump?
What size wheel / tires are you running?
Where did you get the strut tower brace?
Thanks,
I have not yet but Will soon! W/ ROUSH Cal ph2 I was 542hp/454tq
Yes...real easy, dont need anything other than a ratchet & socket! going form the 85mm pulley to the 82mm pulley you can run without a larger idler too cause the phs2 kit comes with a smaller belt than the phs1 kits & 90mm pulley.
Stock...no issues until you get to 79mm pulley I believe
295-30-20 rear (27" overall diameter)....Id recommend going with a taller rear tire if you have 3.73 gears. the gears are really too much for the tires!
Its a stock 2007 GT500 brace I got from craigslist for $60.
I'm having mine installed at a very reputable Roush authorized shop about 20 minutes away from my house call fastlane turbo. There install price is about the same as a dealership (which is high) but I want it done right the first time!
I paid $75 an hour for install from my local roush dealer....$750 total
Bought the kit from HyperMotivePerf.
Had the car back in the days waiting on the calibration....SC was installed on ten hrs
9/1/15 01:19 PM
