Sponsored by:
Sponsored by:
Functional side scoops
Old Jan 27, 2012 | 07:48 PM
wheelman's Avatar
So I want OEM-looking side scoops. This'll be on a '13 I don't have yet, so this is just the idea stage. What I'm thinking is to use a little bondo or whatever to create a seamless flow from the edges of the scoop to the body, towards the fender. And as long as I'm going through all that trouble (including repainting), why not make them functional? For that, I was thinking of just picking up the cheapest brake duct kit I can find, cut the fenders (under the scoops) and route the ducts. Forseeable problems? Scoops you think would work best for this idea? I like the Xenon's on the 05-09s because they match right up to the fender flare, but with the smaller flares on the 10+s, they don't look as good IMHO, so I'm looking elsewhere.
MODS: This probably should have gone into '10-'14 Exterior Modifications, so move if you agree.
Old Jan 27, 2012 | 08:15 PM
whoah's Avatar
whatever you do, dont use bondo.
a welder, a hammer and dolly, a bit of sheet metal, and some cutting will get you real close to the rough shape. the better you can get it at this stage the better it'll look in the end, so take your time early on and do things right. Once you get the sheetmetal as close to the finished product as you can get it, use a sealing primer, and then use a glazing putty or something (other than bondo lol). lots of sanding and shaping, and you're ready to spray your primer, sand, paint, sand, clear, sand, buff etc....
best bet is to ask an auto paint supply for advice on what products to use, they can most likely recommend the best products for your needs, and you get a lot better quality than what you get at vatozone.
Old Jan 27, 2012 | 08:16 PM
wheelman's Avatar
Lol...I've got a body guy who should know better. I wouldn't touch body work. I tried painting and that sh*t is hard enough!
Old Jan 27, 2012 | 08:29 PM
Tony Alonso's Avatar
Brake cooling would be better served on the fronts. The '94-'95 Mustangs had the rear scoops opening out into the wheel well, but it seemed somewhat doubtful if there was any meaningful cooling flow that would get to the brake rotors.
Old Jan 27, 2012 | 08:49 PM
wheelman's Avatar
Absolutely will do the front, but that's easy: new fenders. I'm actually more interested in the look of the scoops (and they'll be somewhat original), but I want to be able to say that they're functional, even if they don't do all that much. So the 94-5s just had an opening, correct; no ducting? I was thinking of just going that route too if the ducting part proved too problematic.
Old Jan 27, 2012 | 08:59 PM
No ducting - it routed air into a louvered opening in the wheel well. Regarding the fronts, the current Boss 302 has the openings in the lower front valence as opposed to the fenders.
Old Jan 27, 2012 | 10:10 PM
wheelman's Avatar
Right; I misspoke. Was thinking front fenders for venting (with the rear fenders on my brain), but plan to do the front ducting with a GT500 front bump. Love the '12 Boss lower fascia look, but no quite as hot on the '13. Thanks for the info. Kinda like that louvered idea.
May 3, 2026 05:42 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
NC14GT
Sep 27, 2015 05:35 PM
