Sponsored by:
Sponsored by:
Engine Vibration
Old Nov 8, 2010 | 03:48 PM
mdun6's Avatar
Engine Vibration
Hey all, I have noticed that when I rev the engine at at about 1000-1500 rpm's it has a bad viration then goes away as rpm's go above about 2,000. Have any of you noticed this with your 5.0's? should I be worried? Could it be the aftermarket tune causing this?
Old Nov 8, 2010 | 06:58 PM
mdun6's Avatar
I put the stock air box back on and returned the stock tune back in the ecu. Still I have a vibration around 1,500 rpm's. I guess it will be off to the dealer unless someone here says there car does the same. Maybe the vct adjusting?
Old Nov 9, 2010 | 09:56 AM
Lancel's Avatar
I really haven't noticed anything like this, sorry. :/
Old Nov 15, 2010 | 07:37 PM
assasinator's Avatar
bolt on the clutch probably backed out or broke off. its happened a thousand times already.
Old Nov 16, 2010 | 04:07 PM
mdun6's Avatar
OK where is this bolt? More details would be great.
Old Nov 16, 2010 | 05:01 PM
caps's Avatar
dealership
Old Nov 16, 2010 | 05:22 PM
montreal ponies's Avatar
I don't think it could be clutch related, but could you give us more details on the kind of vibration you're hearing and where youn think it's coming from. Is it vibrating while driving the car or when it's idling only ?
Old Nov 16, 2010 | 06:52 PM
plenty of pressure plate bolts have backed out. yours and mine can do it at any time.
there is a inspection port on the bellhousing or go to the dealer.
Old Nov 16, 2010 | 06:54 PM
go to the track with sticky tires and do 6k drops. youll find a vibration soon enough.your clutch WILL fail after enough runs.
Old Nov 16, 2010 | 06:59 PM
White2010's Avatar
If the vibration was really bad it seems like one of the knock senors would give an MIL. I'd still have it checked though.
Old Nov 16, 2010 | 07:00 PM
mdun6's Avatar
I only feel it around 1,400RPM to about 1,700RPM. I don't notice it when i'm driving just when revving the engine at a stop and it shakes the whole car. My 15yo son could even feel it in the passenger seat.
Old Nov 18, 2010 | 02:45 PM
a vibration with an accleration higher than 7 mils, will ruin it pretty quick. get it check before it taers itself up.
Old Nov 19, 2010 | 05:45 AM
mdun6's Avatar
I made an appointment for Tuesday to have it looked at. At least i'll have it on record.
Old Dec 1, 2010 | 01:52 PM
mdun6's Avatar
Finally got my car into the services department yesterday and got the answer I thought they would give "this is a normal characteristic for the 5.0". There is a TSB for it now but it stated no repairs should be attempted.
Old Aug 14, 2016 | 10:44 AM
Airassault's Avatar
got a 2014 5.0 gt/cs and just had the clutch replaced. Ever since I got it back I've noticed a vibration at 1100 RPM's. Could this be the pressure plate bolt you're talking about?
Old Aug 14, 2016 | 06:05 PM
SpectreH's Avatar
I'd guess the flywheel/pressure plate need to be balanced.
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Airborne42
Sep 24, 2015 11:01 AM
