Sponsored by:
Sponsored by:
Emissions States..
Old Jul 13, 2010 | 01:37 AM
5PTOHH's Avatar
Emissions States..
For those of you who live in states that do emissions testing, what are your intended power mods? I am assuming that long tube headers and off road x pipes are out of the question?
Old Jul 13, 2010 | 02:29 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
So long as you retain your cats in Texas you should pass.
Old Jul 13, 2010 | 02:43 AM
DynamicmustangGT's Avatar
I have an 05 with longtubes and an o/r x pipe. We are pretty strict here.
Old Jul 13, 2010 | 05:29 AM
5PTOHH's Avatar
Where do you live? I am moving to Colorado and not too sure how strict they are going to be.
Old Jul 13, 2010 | 09:33 AM
KonaBlue5.0's Avatar
In Maryland, they have completely done away with the dyno rollers, and just plug up to your OBDII port to check for engine codes. If you have none, you pass. There is always the possibility of a visual inspection, but they are randomly selected - not every car is subject to it.
Old Jul 13, 2010 | 09:38 AM
Doogie's Avatar
Same here in WI... it is no codes = pass
Old Jul 13, 2010 | 02:16 PM
SuperSugeKnight's Avatar
In California, as long as the part has a CARB EO# on it, it's good to go. Most superchargers have that. Very few CAI's have it. For exhaust, you can't remove the factory cats. And long tube headers are illegal. Some shortie headers are legal though.
Old Jul 13, 2010 | 03:26 PM
But, but, my cats fell off officer. I couldn't find them. I definitely didn't intentionally remove them.
Old Jul 13, 2010 | 04:18 PM
Ugh. I hate this state for modding cars. **** hippies.
Old Jul 14, 2010 | 06:52 AM
OBleedingMe's Avatar
More like **** yuppies. Hippies are too baked to vote or attend town hall/city council meetings.
Old Jul 15, 2010 | 01:25 PM
Lancel's Avatar
Georgia has emissions in the Atlanta metro area, which is fairly wide reaching, and gets draconian with older vehicles. Newer vehicles just do a gas cap test and OBD code test. Anything from 1995 and before gets the full run around including a full catalytic converter inspection and an ASM2 test and an exhaust emission check.
I'm pretty sure the sum of it is that you may have to keep the stock exhaust on cars in the covered area. Not sure though, never heard of anyone sneaking by, though the tests are nothing like California's.
Old Jul 16, 2010 | 01:43 PM
Haha eh, either way...
Old Jul 16, 2010 | 08:31 PM
houtex's Avatar
To answer the question: None. I'm kinda a "stock is good" guy.
However, if I had nothing but money to throw at it: Everything legal and still pass.
Old Jul 16, 2010 | 08:54 PM
RedCandy5.0's Avatar
The best mods you can do is a tune with a CAI so you can return it back to stock when testing comes. Plus a cat back but thats for sound and not much power gain.
Old Jul 16, 2010 | 11:12 PM
Ltngdrvr's Avatar
Every state is an emissions state.
96 and newer cars are all OBDII so most areas that test on those cars is just a plug-in.
95 and older get the rollers and tailpipe sniffer.
Emissions testing in states other than CA. is dependent on population density for how much testing they have to do.
Here in Texas, Harris county(Houston) and the five counties surrounding get tested, Bexar county(San Antonio) gets tested, and Dallas and Tarant counties(Dallas/Ft.Worth) and the surrounding counties get tested, all other counties in Texas sqeak by with just a safety inspection.
I have never had any inspector look under my car to check the cats, had one squeak about a CAI but didn't hold me up. Basically on aything undercar it is "don't ask, don't tell" so long as it passes OBDII or the sniffer.
Old Jul 16, 2010 | 11:38 PM
First: There are several states with absolutely no emissions testing. Florida, for example.
Second: By most state guidelines, inspectors are required to check for a cat. Does that mean they actually do? No, not usually, unless you give them a reason to.
My old RX8 was quite loud, but had a resonated mid-pipe. I got screened for no cat, but luckily the resonator happened to look just like one, had a bung for an O2 sensor as well. With a tune defeating the rear O2 sensor, it was a win-win situation.
Old Jul 16, 2010 | 11:53 PM
Ltngdrvr's Avatar
Whether the state does emission testing or not, all 50 U.S. states are emission states per federal law.
As far as being required to check for cats, I'm sure all states are but at least in Texas they don't unless the car fails either the sniffer on older OBDI cars or has a cat related code come up on OBDII plug-in test.
And in Texas, once the car is more than 24 model years old it doesn't have to pass any emissions test.
Old Jul 17, 2010 | 12:12 AM
Only 20 more years to go.
Old Jul 19, 2010 | 02:10 PM
coffeejolts's Avatar
I'm glad my 1981 Corvette is exempt from that madness. The car is stock so it would probably pass, but who knows...
Old Jul 19, 2010 | 04:05 PM
5PTOHH's Avatar
So if you do get checked using the port what exactly can you get away with? Can you go xpipe with exhaust,headers, and CAI as long as you run a tune to delete the CEL? Sorry for the dumb question, but this is the first time I have lived in a state that does emissions testing.
