Drag radials...Tires.....???
I'm looking for a good set of drag radials for my 2012. I've been running the NITTO NT555 for about 9 months now. I'm looking for something w a little bit more grip, something more aggressive. Does anybody know or recommend a good set of drag radials to try out, and what's the best size to get???
I have the stock brembo 19" wheels btw
A Man Just Needs Some....
MT ET Streets are the best radials you can get for grip on dry pavement. But they are the worst in rain. I've driven both Nitto's and MT ET Streets in the rain. Nitto's handle just fine. The ET Streets on the other hand are scary in the rain.
I take it your car is a manual?
Best hook for a drag radial on a manual is going to be on a 15" wheel, and either a 275/60-15, 28" tall, or with 3.31 gears, use a 275/50-15, 26" tall.
Going with a 15" wheel gives you a taller sidewall to help absorb the shock load from the clutch engagement on launch.
